The M8 ROM in boot has a different ntfl and mali KO files.
I also see it doing something different with AML keys which I think might solve the paid app install thing!
System looks almost the same except for wifi.
Kernels are for sure different!
BUT, do not flash the M8 ROM on your S89. You will hard brick due to bootloader!
I learned the hard way and it took 3 hours to get unbricked.
It's because bootloader is different as the M8 uses a different NAND chip that the S89.
However if you use the S89 bootloader, the M8 ROM and kernel does boot!
