Flashable stock Minix X7 Pre-010 ROM
    Hey folks I figured some would like this. I know many will say WTF is up with Bob? Well read on.
    This is the Stock Minix Pre-010 ROM in a flashable format.
    Nothing has been changed!
    Because 009 and Pre-010 are update.zip files not full ROMs, I decided we needed a flashable stock Pre-010 ROM. Why? Because if you ever want to test other ROMs to go back to Pre-010 you have to use CWM or flash 008, update to 009, then update to Pre-010.
    Pain in the ass!
    Well to do it right this is what you have to do. Anything else can leave /data shit you don't want!
    E.G. IT'S NOT clean!!!! I do not like update.zip updates! It is not clean and can leave you with bugs from the previous releases in /data and Dalvick.
    Also having a complete Pre-010 flashable ROM allows you to fully erase and flash so you KNOW you have a clean install!
    How did I make this you ask?
    1) I erased and flashed 008
    2) Without doing ANYTHING that could change something, I updated to 009 using the zip.
    3) Then updated to Pre-010 same as 009.
    4) Then using the RK 2.1 tool I dumped all the paritions.
    5) Then to reduce wasted file size space I properly trimmed the .img files to the used length.
    So you know dumping dumps RAW the full parition. So for instance recovery partition is 32 Megs RAW.
    But only 13 Megs of it are really used and the rest is EMPTY.
    With a RAW dump you would flash the empty parts too.
    Not needed and make Download too big as well as flash time.
    6) Then I put all the parts together and made a flashable ROM.
    PLEASE NOTE. There is no kernel.img because the kernel is inside boot.img on the stock ROM!
    Thus you wont be able to flash any seperate kernel.img images on the stock ROM.
    When kernel is in boot, it is always used vs kernel.img
    Thus in the flashtool kernel.img is unchecked. If you check it, you will get an error!
    So there you have it.
    A stock Pre-010 flashable ROM so you can quickly get a CLEAN Pre-010 installed.
    For instructions to flash this, see one of my other ROMs.
    I expect you know what your doing if your using this so there ARE no instructions inside the download!
    P.S. later I will make a Finless ROM 1.9 from this.
    That is if anyone cares enough to have one due to all the other nice X7 ROMs out now.
    Oh but wait... There's more!
    More you say Bob? Hell yes
    Below is also a update package I made that will root the stock firmware!
    Yes, it's an update.zip NOT something you flash! Instructions are inside the zip.
    Read them and use it if you want full root on 010 firmware.
    __________________________________________________ __________
    Here is the stock ROM "flashable" download
    ROM -> Minix Neo X7 - Stock Pre-010 "flashable" ROM (428 megs)
    Here is the rooter tool package "update.zip"
    ROM -> Minix Neo X7 - Stock ROM "root" kit - update.zip (2 megs)
    Enjoy,
    Nice!!
    Thanks Bob.
      And a question
      Can I use rooter tool package to root pre 010 firmware which have been updated from stock 009?
      I don't want to make a clean install now. I'm still waitting for the finless 1.9 room
        Bob,
        Why not extract kernel from boot and repack without? Then you can have alternative kernels.
        Donate to Finless
          @Finless, I want ask your permission to link this your post to another forum outside freaktab? Thanks!
          "Nice Work!!!"
            yes 1.9
            many good roms.
            may I dream a bit here Bob ?
            I wish for a cleaned rom that combine the HDMI/Audio fixes with pre10 and best possible wifi/lan with a preinstalled Beyond XBMC (flumpsty) and latest Gotham beta3 - so people can mess around themselves since they do not interupt with eachother.
            also i wish for a preinstalled
            Netflix HD
            1080 kernel
            mild ram OC
            Viaplay that works in HD for android (nordic stuff)
            updated google office/store
            root
            and most of all
            some game emu like retro arch that works with controllers/keyboards including some roms samples already (like xtreamer*)
            and perhaps a few nice launchers to choose from.
            ok dream over :P
            go for it master Bob. honestly
              D33, I did not remove kernel because I wanted this stock for people that want stock. Believe it or not there are quite a few that do! Also having the kernel out of boot "may" cause Minix OTA update issues for those that use it in the future.
              I was debating making the stock ROM with kernel removed and pre-rooted but then it's not stock is it
              So that's my thinking.
              eyeyousee, yes feel free to post elsewhere. But please link them to this post not the direct download link. This site lives by having advertisers and user see those ads. If they don't come here then that gets broken. Make sense?
              Theklavej, I guess you might be dreaming a lot. I do my ROMs a certain way and it's not adding APPs to it. I make clean fast ROMs that are pretty empty of APPs, etc. This allows users to customize it the way they want. With the pre-install script in ROMs, anything you want installed on first boot can happen by putting them in a folder on SDcard. Then first boot it will install them. All the Devs have this script in their ROMs these days. Well many do anyway.
              As for updating the Google framework and core apps, I always do that
              Same for adding fixed and 1080 kernels.... I just wont add APPs that users can decide if they want or not.
              Originally posted by mr.caotheanh View Post
              And a question
              Yes it will work!
                ok Mr. Finless, I did not notice the kit attached earlier, I will try it out! Thank you very much. oh, and yes i'm always posting direct links to other forums! thanks again! have a nice day!
                  FYI, one of the reasons I have not jumped on the 010 release and made a 1.9 ROM is because this is a BETA 010. I have been waiting for the final release to build from thus saving double work. As you know I work on many many other devices so time is a little limited!
                  However, if the final 010 is not around the corner soon, I may have to bite the bullet and do it. Again it's how many people really want 1.9 based on a BETA?
                    It wiil be another beta first (may come this week) after that a final 010.
                      ...how many people really want 1.9 based on a BETA?
                      Even if this pre 010 beta is the best FW I've tested since I got my X7, I'm sure it's better for all of us that you wait for the final version.
                      Thanks for this flashable version btw
                        The Root Kit works! Thank you very much Finless Bob!
                        Sent from my NEO-X7-216A using Tapatalk
                          The root kit work done, what's a very simple way to root, thank Bob Finless
                          Another comment about how Minix work good with x360
                          tincore said me that Minix stook room missing some input module, and he recommend me to use Quickshoot rom.
                          I've just check several version of stock rom, your Finless rom allways missing these file:
                          Vendor_045e_Product_0291.kcm,
                          Vendor_045e_Product_0291.kl,
                          Vendor_045e_Product_0719.kcm
                          Vendor_045e_Product_0719.kl
                          That's why user have character spin continuously problem when using x360 in shadowgun and GTA game
                          Everytime I use Finless rom, I must copy these file to suitable folders, it's easy for me, but not easy for normal user.
                          So I would like if you will build in these missing file, give more adjust in the Finless 1.9 rom
                          so x360 gamepad can work good on it.
                          Very thank again.
                            We really want stable KitKat from Bob.
                              I'll second that. It would be nice.
