Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
    Originally posted by Arbelzapf View Post
    It would also be a support nightmare. People would put cheap knockoff 2gb cards in their devices and then ask for a refund when the inevitable corruption orrurs. The manufacturer cannot reliably issue OTA updates since he cannot know howhow much space the user has.
    I know this sounds interesting for experienced users, but there are very good reasons internal storage is better kept on-board
    +1
    RK3288 Devices
    - Overview BOX (LINK !)
      Originally posted by no_spam_for_me View Post
      ( => I think one and we all know from which guy )
      Might not be from me (if that is what your hinting at)!
      Seems you testers are getting boxes before we do
      Probably a good thing to test stock!
        I'm sure Oman will have one coming your way Bob, would be a travesty otherwise! If not ill happily forward mine to you once I've had a play, better off in your hands than anyone else's for sure
          Of cause that's what I hinting at
          BUT Bob, do you really need at box to customize the rom? Hey, come on, it's a rk image
          And believe me, if we don't get a stock rom to flash, the first step I will do is to dump the stock rom
          RK3288 Devices
            Originally posted by oman View Post
            Yes,good advice.
            At the beginning,The only ROM is from me..And what I were fixing is OTA update in the past several days,there is still some problem..If OTA is available ,there's no need to update by hand..
            You can test everything you can,the more severe the better,but not try to put it into fire..cooked it
            You can install any APPs,mount any peripherals ,usb stick/HDD,camera,Remote..just tell me the model of them,the Logs when issues happen,the version of APPs,the process of reproduction..and so forth.
            I plan to discuss different kinds of issues in separate thread,such as xbmc,wifi/ethernet,hardware,peripherals,multimedia,stability ,APPs.....
            Guess I picked my vacation at the wrong time
            Hope I'm not to late as I'm just back from my vacation.
            Did you guys allready got the R89 ? Haha.
            DHL + Gift (Or Sample) + <20$ Value is fine in Germany.
            But make sure to stick a CE Logo on the Device and the Charger.
            German (European) Customs look out for devices without. If they open a package without a CE Logo --> They size the device !
            So please take care about that Oman
            PS.: info/email sent
              Re: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&amp;developers
              @omam: info/email sent
              No not yet so don't stress, don't think he's started to ship them yet as been weighing up delivery options and no doubt ironing out other issues before he's happy to send them out way. Am itching to get that "there on there way" notification, can't way to test this one
                Another brand says RK3288 deliver antutu 45000+ clocked at 2.016 GHz with an added fan abow the heatsink
                As your board gets 40208 at 1.608 GHz (competititor 38655) we might not be far away from 50000 if we clock the board at 2.016 GHz and add a fan abow the heatsink?
                Is that other board also made at your factory?
                  Forget the AnTuTu scores, believe me, they are often faked by code at the kernel, and I think they are also faked at rk source...
                  More would be interesting to know which size the fan had they use at this test... Maybe 40mm?
                  But nice to see which effects this fan has (~90°C vs. ~60°C at open case)...
                  RK3288 Devices
                    You can see the minifan in a picture in the link below:
                      Yes I know, but 30 , 40, ... mm?
                      And what I'm also missing is some information about the SoC usage during the temperature measurement...
                      RK3288 Devices
                        i need Rochchip sources for the 3.10.0 kernel. Are there anyone that can get the sources so i can cook up a kernel for overclocking i have the same board too. here is a link from other site that i am port of there are my pictures and also the dump for ref, i also rooterd my board very easy.
                        http://www.arctablet.com/blog/forum/...ware-20140731/
                          maybe this helps
                          RK3288 Devices
                            hi,friend,this file is the install software,you can download it to upgrade it,
                            this is link:http://www.mediafire.com/view/1438pd...ing__Steps.doc
                            http://www.mediafire.com/download/00...y_Updating.rar
                            an other link
                            http://chinagadgetsreviews.blogspot....1_archive.html
                              We are trying our best to make some bugs fixed in the last weeks.
                              Unexpected things always happen..
                              I hope I can send the samples out in next week...
                              Update some info:
                              After increase Cpu freq to 1.9G,and Gpu to 600M, Antutu benchmark can be up to 45k..and running CPU_PrimeBenchmark overnight,it still be running in the morning although very hot,I think the Board quality can hold that frequency...But it's a little difficult to run into OS when cpu in 2.0G ,I didnt try using a fan,maybe it'll be working.
                              About Dts/dolby,after talking with RK ,they told me that we should get the licence from Dts/dolby,if not they wont support us about this,it's a software things,not hw....If so,I believe our devs can fix that problem,so dont worry..
                              HDMI2.0 are still on the way...
                              And we design our new UI:
                              Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
                                Eye-friendly colors
                                EDIT
                                CPU Prime Benchmark?
                                With this tool and the 'prime calculation' I freeze my rk3188
                                RK3288 Devices
