Kit Kat 4.4.2 RK3066 (Fully Working)
Sound issue
Hi guys,
@Shomari this is really great ROM, much faster and slicker than finless 2.0 that I've used. Unfortunately my imito mx2 has that weird HDMI sound issue so basically until this gets fixed It's quite unuseful. I can confirm that finless and stock rom had that SIMC fix in the kernel, I've flashed them back and looked into the dmesg, when it doesn't get EDID response it switches by default to HDMI instead of DVI like this one. Can someone give me the kernel source, or apply that fix so I can use this kitkat beauty at last ?
Hi, I updated my tv stick using the rom of this thread, Have the stock rom and have to press a buttom next to the microsd. First of all have some issues with Wifi, but now is working but my problem is that it freezes everytime I watch some video I opened and the rockchip chip is so heat. I can't use thestick like this but now I can get the flash mode pressing the buttom that I mencioned on the beginning to change the rom to other one. What Can I do?? Please help me...
Originally posted by duendedoz View PostHi, I updated my tv stick using the rom of this thread, Have the stock rom and have to press a buttom next to the microsd. First of all have some issues with Wifi, but now is working but my problem is that it freezes everytime I watch some video I opened and the rockchip chip is so heat. I can't use thestick like this but now I can get the flash mode pressing the buttom that I mencioned on the beginning to change the rom to other one. What Can I do?? Please help me...
Working MX2 Kernel with fixed sound
Ok, guys I've managed to find kernel source and successfully compile it with sound fix mentioned before. Unfortunately wifi and bluetooth are not working right now. Major issue at least for me was the sound, I have an usb ethernet adapter that works so I'm able to use this ROM on regular basic. I'll keep trying to fix the WIFI and BT drivers (I already have gpio dumps).
This sound fix should also prevent sound issue after suspend (not confirmed yet)
For anyone else interested you can get this kernel here :
Flash procedure:
1. Open AndroidTool 2.1
2. Select "Download Image" tab
3. Clear all the checkboxes except the "4. Kernel"
4. Click in 5th cell, browse / select the kernel.img
5. Click "Run" button
Wait few minutes, disconnect your imito and you're ready to go
PS. Since I've saw that some of you needed the tun.ko module, here it is (working with my kernel and it should be compatible with stock 3.0.36+ kernel as well)
Originally posted by Shomari View PostThose of you with iMito MX1/MX2, UG007II, MK809II, J21 and MK808B with MTK chipset are in luck; Kit Kat 4.4.2 is now fully functional on RK3066 for your devices.
Overclocked Kernel - 1080p (try at your own risk - CPU 1608/GPU 400/DDR 600): https://mega.co.nz/#!6N5RVIBD!48i4hG...g85DAQ7LYSUahE
OC Kernel - CWM flashable: http://ge.tt/8IXOyRn1/v/0?c
Stock factory kernel is 1080p ← (click for info)
stock speeds are CPU 1512/GPU 240/DDR 396
ROM MIRROR (faster): https://mega.co.nz/#!6cJkWDDY!-VT74e...kqkTYcjPm_KVn4
Linux compatible (separate .img files) use rkflashkit: https://mega.co.nz/#!mEJ21QjS!X7kAQw...aAMbf2OvZF6Dpo
Factory download link ↓:
CWM: Download Arctools https://mega.co.nz/#!zNpiSTZB!DIy4BR...aHVlfLfglAWA8I and select (OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2) in packages. Download and install, reboot. You must select the Oma package for full CWM compatibility.
Users experiencing 'android is upgrading' on every reboot - click here for fix (thanks to himmon)
Click here to Enable Location Services in ROM
Passthrough audio - YES
...thanks to dfgas for confirming this ROM is Netflix HD capable. (video below)
Does anyone know how to make full backup of the Rom in .img file? I want to save the rom in the actual satate , with all applications and settings. Thank U
Export images
Use the AndroidTool 2.1,
on the Advanced Function you have ExportImage button with two entries Start/End.
This would be the steps to dump the various partitions (img):
1. Unpack the firmware with AndroidTool, look into ./Output/Android directory and open the "parameter" file with text editor.
2. Look for something like "0x00100000@0x00564000(system)", those are the values you need to put for start and end
This should do it, but be careful as this is something you do on your own responsibility.
Originally posted by canadien View PostJust a question about this rom…
My mk802iiis OTG port is kapout. Can one expect a tf card update for this rom or it is100% sure it will never exist?
Thx
For ROM manipulation you can use Sergio's tools :
There are currently 3836 users online. 0 members and 3836 guests.
