ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by mel4787 View PostTrue. But how can we manage battery on these things
The only suggestion as I can make is to check out Greenify... you might like it.
ShaunMT
P.S. Apps like Greenify may not work correctly considering Android doesn't properly report the correct battery level.Freaktab Rom Developer
Big question, what have you deciphered
and can we use the kernel built for this device for cm11? Reason is many androids have used stock kernels to boot custom roms
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostYou are going to have be more specific. I don't know what you want to know...
The stock kernel should work for any current Android build. (CM11, ParanoidAndroid, OmniRom, AOKP, etc...) The challenge is creating a device tree to build one of these ROMs for our device with all of the necessary drivers to support the various hardware components. We are part way there now that I have TWRP compiling successfully.
ShaunMT
For the next book, what have you gathered on it?
Do you have info on the next book to make a ROM yet
Originally posted by shaunmt View PostHave you been reading the forums? I think I've shared everything I know...
I think you mean can I compile a non-stock based ROM from source or port one from another device. I think so, but it's going to require a lot time to setup, compile, debug, recompile, retest, etc... It's not a quick or easy process...
ShaunMT
Originally posted by mel4787 View PostI understand. The help was great. Got all the answers I was looking for. So is twrp ready for testing
Right now, it doesn't support rockchip update images (yet) and the only way to switch between TWRP and stock recovery is to flash the recovery partition via one of the many PC rockchip flashing tools. Do you know how to do that?
After I make a few more changes, I'll be looking for a few people who want to test the normal TWRP features, while I work on porting the rockchip update image code to TWRP.
Originally posted by mel4787 View PostHmm ik how to do that. I have a rockchip program to flash images. And twrp I will test it. But I like cwm better. Think you can port cwm as wellFreaktab Rom Developer
Originally posted by mel4787 View PostIs it 4.4.2? I'll test his out but I like your ROM betterFreaktab Rom Developer
Originally posted by mel4787 View PostBesides the dual boot what are the differences between yours and his
I think he increased /data to 2GB and added some drivers for gamepad and vpn support.
There are currently 4150 users online. 0 members and 4150 guests.
