=> http://www.freaktab.com/showthread.p...l-TV-Hulu-etc)
Amazon Prime Instant Video CRASHING on s89 but not other android devices
Maybe the following discussions should happen at?
=> http://www.freaktab.com/showthread.p...l-TV-Hulu-etc)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by daniello9 View PostCrashes when movie should start to play!
It opens fine and let's you select movies but when you press play the screen goes black and .. *bang*
Amazon Instant Video is not usable on my box. Screen goes black and box has to be rebooted to work again...
EDIT: I am using a T-R42 with wasser firmware...
Originally posted by Deviant-AUT View PostI solved the problem!!!
Use hdmi virtual switch.
Its not as smooth and with low bandwidth by far not as good as the netflix app but it works for my tr42 4.4.2 tv box =D
Hell yeah!
Edit: Found it .. it's an app .. for anyone stunned .. search in Freaktab.
Regardless of that it doesn't work here. When after I virtually pull hdmi Instant Video still FCs on my tronsmart :-(
Originally posted by Deviant-AUT View PostMake sure your device is rooted.
You have to install the hdmi virtual switch first
Download here
Open the app and deactivate hdmi. Movies should work now.
Originally posted by Deviant-AUT View PostOk, i think you have a different problem.my app never crashed or closed. The screen went black but i still got the sound of the movie.
rk3188 KitKat isn't a real KK (it's a mod running on the same kernel like JB) so 'hdmi virtual switch' works at rk3188 KK but not at the newer kernel of the KK at amlogic and so on...RK3288 Devices
Originally posted by wollo View PostYes, I got it installed via the Amazon app store without problems.But when I try to play it shows a white screen and then goes back to video selection.
All on stock 108k
Anyone found a fix yet?
There are currently 3701 users online. 0 members and 3701 guests.
