Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Deezel View Postso to get into recovery mode you are pushing a toothpick into the reset hole while unit is off/ then while still holding the toothpick in the reset hole you are turning unit on and keep holding reset with toothpick for at least 20 seconds?
Re: Square M8 JustMe Rom 20140901
Originally posted by lowsum View PostThis is what I use:
You can choose any app as your default home launcher.
Originally posted by Nickdot View PostThe problem that i have is : Everything is working fine. When i press the red button to my remote control to switch off the M8 after 10-15 sec the box close. But i can't switch it on pressing the red button. Any help please?
Originally posted by Nickdot View PostThe problem that i have is : Everything is working fine. When i press the red button to my remote control to switch off the M8 after 10-15 sec the box close. But i can't switch it on pressing the red button. Any help please?MY MINI PC: C4,CS918,M8,M8C
Originally posted by darekmarta1975 View PostI asked the same question, and one I still did not answer
WakeMeScottie.apk
JustMe had to use an app to keep a service alive to allow the box to wake up.
This was in V 1.2 but not in V1.3
I extracted it from V 1.2 (JustMe - hope you don't mind, but I don't think some folks here know hoe to do that )
I attached it , download,install and run it, It requires a restart if the box is unplugged from power.
Still a bit flaky (for me it requires that the power button be pressed for at least 3 secs and not over. The blue led also stays on.
Hope this helps.Last edited by dy57; 11-09-2014, 07:24.
Sorry for being ignorant how come finless doesn't require this app to run in the background?
Still a bit flaky (for me it requires that the power button be pressed for 3 at least 3 secs and not over. The blue led also stays on.
Hope this helps.
Originally posted by Crows View PostSorry for being ignorant how come finless doesn't require this app to run in the background?
This JustMe ROM is appears to be a Hybrid of a custom kernel from Oman or Stane. Great performance and video quality if you don't some minor quirks....
There are currently 3455 users online. 6 members and 3449 guests.
