I did a test and it's the 1gb version. It also works on a 2gb version but shows only 1gb.
OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by versus4582 View PostDoes this rom support MX3 1GB ram version ???? If not do you guys have any other link for an OpenElec Rom for the Mx3 1gb version???
On the other hand, if you have the newer AP-6181 version.
Then you'll find that WiFI is kind of a hit or miss. In my experience mostly a miss.
Though to be honest I haven't tried v5 yet to know for sure.
But, prior versions had problem's though.
Given the nature and a lack of a real Serial Number care of IMEI or a MEID the Android ID is auto generated each time I either install, or reset the Firmware.
As an upshot to that I'm only less inclined to want to play-test such Firmwares at the expence of adding more Devices to my Google Play Music List.
Though there are ways to get round it though...
This is my first time using Openelec, so please pardon my ignorance. I installed version 4.97.3 on my Vega S89H and all went well. I have my box connected to my A/V receiver, the video was great, but could not get any sound at all.
My objective is to get the tvheadend server installed so my box will be a self contained PVR box. It has drivers for my HDHomeRun tuners included. I think I installed the tvheadend server, but have no idea how to use it with the tvheadend PVR client.
Maybe someone can give me some pointers on my problems.
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If you have installed tvheadend server (backend) you should be able to connect to the webinterface this way:
There you have to make all needed configurations.
Maybe this could help:
But that's for the old 3.4 version. The new 3.9 looks a bit different.
If the backend is completely configured you just need to activate the pvr-client. I think all needed settings are preset.
Originally posted by MikeD View PostIf you have installed tvheadend server (backend) you should be able to connect to the webinterface this way:
thanks for your suggestions.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I think there is no really good browser available for openelec. There is only a very rudimentary one (only text) to install from the repository.
Tvheadend is working on this openelec release. I tested it with a USB DVB-S2 module but I still have problems with drivers. You have to install tvheadend from the service addons. In configuration you shouldn't enable "wait for adapter" to get it directly started on booting. Then you could enter it's webinterface from PC/Mac with BOX-IP:9981 typing in the browser.
Sound should work, WiFi also (but isn't tested by me) but bluetooth isn't working at the moment (I think no drivers included).
I use the latest 5.0 release but with 4.97.3 there shouldn't be a problem either.
Do you use these builds?
Originally posted by MikeD View PostI think there is no really good browser available for openelec. There is only a very rudimentary one (only text) to install from the repository.
www.amlinux.ru/image
I am going through a new Denon A/V receiver, instead of directly to the TV, but maybe that is why I have not sound.
Again, thanks for your suggestions, and letting me know that tvheadend will work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by MikeD View PostI use SPDIF to my audio receiver and enabled pass-through in audio settings. That's working for me. But if I enabled stereo upmix I also get no sound. I have to uncheck this.
Did you try out some settings to get sound working?
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by MikeD View PostAlso check if passthrough of AC3/DTS/etc. is enabled depending on your a/v receiver. It's below the common passthrough setting.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I still did not get the audio to work, it shows a red speaker icon on the top right corner of the screen, and I tried all the settings. I did install the 5.0.0 version today. One thing I noticed on both versions I have tried, when in the settings menu, when my cursor touches the"audio" section everything freezes for a couple of minutes. This happens every time, using my air mouse or stock remote.
Anyway, my goal was to get the tvheadend server working on this Android box, and with your help I succeeded. Now to YouTube to figure out how to set it up.
Thanks a lot
Update: Using my computer I was able to scan all my channels and even play some HD channels on my computer. With out a file browser, it will be hard to add the xmltv file to the appropriate location inside Openelec.
Update 2: my Android boxes feed into my AVR, when I switched to my other Android box, my S89H with the Openelec froze. This happened every time it was not the active port on my AVR. Is there a way to keep it from freezing?Last edited by clarkss12; 01-09-2015, 05:28.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 10531 users online. 4 members and 10527 guests.
