OpenELEC for s82, M8, MXIII, Tronsmart S89
So openelec 5.0.8 - 5.0.0 has no wifi working. going to try stock fw to see if i can get it back because 111k4 wifi will not turn on as well do you think this mxIII 2g has a new wifi adapter ? never had this happen. it was on 115k4 out of the box im looking for the right stock one and going to give it a go. thanks .
Originally posted by backintheday View Postya nothing is working to get openelec with wifi i even went to mxIII plus 202 hoping wifi would kick in but no luck . kinda fd thinking of tronsmart img 06032015 trying now. any help
Thus why you have 202k4 Firmware (IIRC), AND NOT 11xk4 Firmware.11xk4 are for K200 devices such as the M8, S82, S89, or the MXIII (M82), which again should all be S802 SoC Devices.
Hi All
I have what appears to be an MX3 however when I load OpenElec 5.0.8 there is no wifi (I have tried turning off wired) and no bluetooth, apart from that all works well
The board in the device is marked MX3-M82-v3.1 and on board appears to be a chip marked AP6234 which I assume is the 6234 WiFi/Bluetooth chip.
Is there any way to load a driver for this chip ?
Thanks in advance
Could someone help out, I currently have 5.0.08 working fine on tronsamart round box, so I wish to upgrade to Kodi 15 beta 2, so which of these file do I need, I am guessing is the one with .tar at end.
if so what is the used for the other two system and Kernel, do they have to be install too.
Thanks for your imput.
OpenELEC-Amlogic.arm-S82-5.95.1.zip 10-Jun-2015 11:48 110M OpenELEC-Amlogic.arm-S82-5.95.1.tar 10-Jun-2015 11:48 104M OpenELEC-Amlogic.arm-S82-5.95.1.system 10-Jun-2015 11:48 94M OpenELEC-Amlogic.arm-S82-5.95.1.kernel 10-Jun-2015 11:48 9.8M
All those images from target folder are test builds. Some may work more or less. But for stable releases you have to wait until developer puts the final images to amlinux.ru/image.
e123enitan I think best is you use OpenELEC-Amlogic.arm-S82-5.95.1-update.zip for updating in recovery. Only this way you also updating system and kernel if there were made any changes in new version.
There are currently 10276 users online. 5 members and 10271 guests.
