The box comes with Kodi 14.0-alpha2 preloaded and it seems to work well enough: the only major bug I could find is LiveTV mini-display not showing correctly under Amlogic H/W acceleration. This was noted as a problem in one of Stane's 13.2 releases too.
I tried SPMC and 14.0-beta2 but neither worked with Amlogic h/w acceleration enabled: giving the infamous black screen/no video problem. Mediacodec accel works OKish, but not good enough for HD.
The firmware is not rooted, and I haven't been able to find a successful method so far. Would rooting allow me to fix the Amlogic problem with stock Kodi/SPMC?
Are there any other custom f/w available for this box?
Does anyone know the true identity of the board/box?
Any tips appreciated.
PS Stock firmware is available at http://www.sumvision.com/product/cyc...x4support.html
