Hi I have a Tronsmart T428 TV Stick but there are no more updates for it
At the moment I have "T428 KitKat Finless ROM 2.0" Firmware on my T428 Stick.
It seems to work good but there is a problem with sound (volume).
T428 and X7 seems have the same hardware specifications:
RK3188 Quad core, ARM Cortex-A9, 1.6GHz Max
Quad core Mali-400 MP4, 533MHz
Hynix DDR3 2GB, Frequence:1333MHz
Broadcom AP6330,Wifi 802.11b/g/n, Bluetooth 4.0
Only the NAND FLASH on X7 is bigger -> 16GB instead of 8GB.
So my question is: Can I use one of this ROMS on my T428?
MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.1.0 )
QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Minix Neo X7 - Finless 1.9 ROM
Which ROM is the best at the moment for Video Streaming? Which can I use?
Can i brick my Stick if I use one of this ROMS? When yes, is it possible to unbrick it later?
