NEW - MK808B-Plus - Finless ROM 1.1
Hi all :-)
I just got the MK808B-Plus with 111K4 rom with the new WIFI, the problem is that the min/max CPU frequency is wrong:
Max:1.2GHZ
MIn: 96Mhz
If I set it to 1.5GHZ it returns to 1.2GHZ after few minutes, I tryeed to set it to 1.5GHZMax/Min and I got 1.2Ghz max and 768Mhz min and now XBMC can play 1080P videos, without this XBMC can't handle 1080P video and looiks like 5 FPS :-(.
How can we make CPU FIX for the Min/Max frequency like you did for the S89 VEGA?
I installed Finless 1.1 on my MK808B+ that shipped with 111K4 rom this morning. The installation went well, but left me with no wifi.
I rolled back to a stock 111K4 rom that I downloaded from
https://mega.co.nz/#!XYEnlC5D!a4fWUZ...PoaeOi_KfCZCio
and that got my wifi working again.
*I am also interested in a new finless rom that supports this new hardware.Last edited by waterlover; 06-19-2015, 03:31.
Max:1.2GHZ
MIn: 96Mhz
It is Tronsmart brand?
Thanks a lot.
Originally posted by ididmytime View Post
Good luck getting the first revision.... so far there has been three.
Rev 2 has the AP6210
Rev 3 has the AP6212
They are not clones, they just come with newer chipsets. Gearbest is definitly shipping Rev 3 since I have received one recently. I also got one from Geekbuying which was Rev 2.
Openelec is fully supported on any revison, but if you want to run custom you will have to check to see what rom it is based on supports the chipset. AFAIK no custom rom supports Rev 3 currently.
Edit: Forgot to mention, if you're UK like myself Geekbuying will give you a fully UK plugged PSU, Gearbest will give you one of those cheap travel adaptors and an EU plug which are awful.
Originally posted by ace9094 View PostWhat is the difference between the Tronsmart MK808b+ and the MK808b+ other than price?
on geekbuying the Tronsmart is £19 but the non brand version is £24
MK808B+ (4) | Tronsmart MK908 (2) | Unbranded MK908
Samsung Galaxy Note 3 | Asus TF300T (2) | LG Spectrum (2) | Archos A5H | Archos 43
"Never try to teach a pig to sing;
it wastes your time and annoys the pig."– P. G. Wodehouse, Robert Heinlein, Mark Twain
Originally posted by ashwaa View Posthow do u know its rev 1 or rev2 just got mine off amazon its diaotec branded wit 110k firmware onboard pls help wanna flash finless but dont know the wifi chip
Originally posted by inforiculturist View PostJust pop open the box and carefully pull out the board and on the flip side you can clearly see what chip is used. It's ap62xx generally, although someone has posted a clone with rtlxxxx chip of some sort.
There are currently 1078 users online. 27 members and 1051 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
