NEW - MK808B-Plus - Finless ROM 1.1
Originally posted by motrac View PostMK808B+ (4) | Tronsmart MK908 (2) | Unbranded MK908
Samsung Galaxy Note 3 | Asus TF300T (2) | LG Spectrum (2) | Archos A5H | Archos 43
"Never try to teach a pig to sing;
it wastes your time and annoys the pig."– P. G. Wodehouse, Robert Heinlein, Mark Twain
Originally posted by ashwaa View Post
how do u know its rev 1 or rev2 just got mine off amazon its diaotec branded wit 110k firmware onboard pls help wanna flash finless but dont know the wifi chip
My Diaotec from Amazon arrived last week with the new wifi chipset. DO NOT FLASH Finless or you'll lose wifi. The newest stock 128k3 works, however. But it's still not Finless and I'm hoping he includes the new drivers and updates the ROM.
[QU=fbueller;n511436]
My Diaotec from Amazon arrived last week with the new wifi chipset. DO NOT FLASH Finless or you'll lose wifi. The newest stock 128k3 works, however. But it's still not Finless and I'm hoping he includes the new drivers and updates the ROM.[/QUOTE]
can u post the screen of ur chipset wit spec device app
and link me to 128k3 firmware
i thought 111k4 is latest
Motrac: the MK808B Plus you get from GeekBuying will be the v3 board with ap6212 wifi chip. It will run Finless ROM just fine, but wifi won't work as the drivers aren't there. As phinc said, it's easy to pop open the box to see what you have. According to GeekBuying's website info, the Tronsmart versions of the MK808B Plus are still shipping with the ap6210 chip which should work with the Finless ROM. I can't confirm, but GB should be able to. However, the ap6210 chip seemingly had poor WiFi reception (although I understand it's better if you can get your 2.4GHz remote dongle further away from the unit). I'm hopeful that the ap6212 is to fix some of those issues. I'm using hardwired USB adapter for my installations, more reliable overall for TS MPEG channels. Hopefully finless will update this device to the 111k4 ROM at some point for those using WiFi, but until then.... Or perhaps someone can figure out how to add the compiled drivers for this and the clone to the existing Finless ROM based on 109k4 firmware.MK808B+ (4) | Tronsmart MK908 (2) | Unbranded MK908
Originally posted by motrac View Postthanks, I also ordered this:
Tronsmart USB2 to RJ45 Adapter
will that allow it to connect to my router if there's no wifi after flashing? prefer wired over wireless anyway.
is that adapter plug and play with the Finless rom?
I know that many of the ASIX chipset based adapters do work. I've been using the Sabrent USB-G1000 (Asix 88178 chipset) devices which are indeed compatible with this device (and the MK908) and Finless ROMs and work very solid.
got my wifi chip no without opening the box
go to esfilexplorer
open device
open system
open etc
open wifi
open 40181
u will get ur wifi chip
mine is written as
ap6210_nvram.txt
hope this helps now flashing lolipop rom
no opening the box or anything
110k4 also has support fr
ap6181_nvram
ap6330_nvram
but no support for
ap6212_nvram
so the people shipped wt firmware 111k4
shld hav the latest ap6212 chipset as 110k dosent seem to support
Finless, i have just installed your rom on my MXV model. Everything works good, but i still see that this rom is also like stock rom regarding resolutions! Even if i set 1280x720, or 1920x1080 in settings, my gui resolution is still 1280x720! This is verified by antutu, cpu-z and Kodi! And all 1080p videos are upscaling in Kodi!
Can you see that?
My old TV-110, was pure 1080p video playing even if system resolution was set to 720p or 1080p!
GUIs are rendered in 720p, but videos should (theoretically) be rendered in full 1080p. What makes you think that they are upscaled?
The lower resolution GUI was not present in older firmwares, so maybe you can solve your problem by flashing e.g. finless 1.0 or older stock rom.
Sent from my C6603 using Tapatalk
Originally posted by ashwaa View Postgot my wifi chip no without opening the box
go to esfilexplorer
open device
open system
open etc
open wifi
open 40181
mine is written as
ap6210_nvram.txt
ap6181_nvram
ap6330_nvram
but no support for
ap6212_nvram
BTW, I am seeing more than one nvram.txt in 40181 folder. I mean, I have all the 4 wifi chip nvram.txt (ap6181, ap6210, ap6212, ap6330) in that folder you had mentioned. Now, how to know which is the wifi chip that is really in there in tv stick from these 4 files?
(FYI, My tv stick came with 110k4 stock rom which I had it upgraded to 111k4 stock rom from tronsmart few days back)Device: Tronsmart MK808B Plus (AP6210 WiFi Chipset)
OS: NAND - Finless 1.1 by DroidTV.fr
SD Card - Ubuntumate 15.04
Originally posted by phinc View PostGUIs are rendered in 720p, but videos should (theoretically) be rendered in full 1080p. What makes you think that they are upscaled?
Check KODI real resolution, and also do that test!!! http://forum.kodi.tv/showthread.php?tid=211244 after you set system resolution to 1920x1080!!!
There are currently 10296 users online. 6 members and 10290 guests.
