MK808 Android mini TV Player - Finless 1.5A Custom ROM
    So why not just try it! Because MK808 has a reset button you can always unbrick. Don't be afraid to flash! Try it and let everyone else know
    Bob/Forum,
    Before I install this ROM, is there a way to save the current system to USB or my PC. This way I have a backup for a "factory restore" - in the event of any errors?
    Thx.
      im pretty tech savy but new around these kind of devices, i hav a brand new ss808 and was going to try to re-flash using all the info here, but all my computers run LINUX.
      cant i use simple flash tools like from "Android sdk" and push this image file???
        changelog
        Hi bob
        Let me first thank you for this awesome rom
        Good job
        do you have already a changelog for your new
        Rom(1.6????)
        greetzz from tha lowlandz
          screen edge scroll
          hi too & thanks so much
          i wanted to ask u, if it's possible to build in a function, that scrolls pages or screen if u hit the screen-edges with the mouse in same direction?
          and some other resolutions for unused old monitors might be nice ofc for HDMI-to-DVI Adapter.
          all the best,
          alex
            Good work.
            Installed and working brilliantly, thank you.
              Originally posted by Deanox View Post
              woops.. here is the link to the new 1080p kernel..
              http://armtvtech.com/armtvtechforum/...893c3&start=70
              Allright then! But...
              I tried this one too. Don't see any real difference in displaying the graphics. Still a bit slow. I can't set my cpu to 1608 anymore. It's stuck @ 1500something. XBMC still runs fine. I'm keeping this kernel until new development has been made.
              I will continue my testing.
                voice search does not work well
                A voice search is started
                talks
                A recognition candidate is displayed
                A voice search forces to terminate
                It is regrettable because others are wonderful
                  AW: NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
                  talks
                  if you are talking about crashing google search with voice, go some pages back... bob wrote how to fix it
                  Gesendet von meinem GT-I9300 mit Tapatalk 2
                    thanks a lot!
                    Thank you for the wonderful information
                    The voisesearch came to operate perfectly
                      Originally posted by Theo001
                      have not tried 1.5a yet but one question:
                      Does it have the option to hide the status bar?
                      (If not, can that be implemented in a later version?)
                      Theo
                      Yup looking for that info too?
                        auto hide is enabled, but not working in all apps... for yt and viedeo players it works.
                          is it working with XBMC?
                          Theo
                          You can use something like "Status Bar Toggle" or "Hide Bar" from the market.
                            Auto hide status bar!
                            Folks AUto hiding the status bar is nothing I can control. Since Gingerbread the status bar has gone through many changes in Android. But the way it has worked since Gingerbread and on, is that an APP must send a command to Android to hide the status bar! There is no way in Android to make it hide automatically unless the APP asks for it to be hidden.
                            This is why some APPs will hide the status bar and other will not. The APPs that do are requesting Android to do so.
                            So for APPs that do not, this is why you have a hide status bar down arrow on the status bar itself. Courtesy of me adding that
                              Re: NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
                              However a custom rom such as paranoid android sports and expanded desktop mode accessible via the power button. On tablets that hides the navigation bar on command irrespective of the app. Is a feature like this not implementable on the mk808.
                              That having been said, I don't own a mk808 but having been reading these forums in anticipation of buying one. Also, thank you for all your hard work.
                              Sent from my SGH-I777 using Tapatalk 2
                                update.img
                                hi, I tried to flash the update.img from deadph1 with the finless tool and selected it in the backup item.
                                I already flashed finless 1.5a and the wanted to flash the deadph1. But after the flash it gave an error.
                                I only selected the backup. What am i doing wrong??
