[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Just an update, I copied the remote.conf file posted earlier in this thread for the HD18Q remote into the config folder and rebooted. After doing this everything is working like a charm. Thanks to the OP for the hard work he put in. You're the man. Also, the rom is super fast, very impressed.
I got 5 of these boxes for family and one for myself, however, they came with a upscaled 1080p version Android rom, which even though showed 1080p in Android settings however, only showed 720p under kodi, which I knew meant that it was upscaled and not true 1080p. Which is confusing as this cpu is fast enough to support 1080p rom, why would they not just make a true 1080p? Also, I opened one of the boxes and was surprised to see that there is an actual heatsink on the cpu, unlike the Beelink MXQ that I have, this definitely seems like better hardware and for some reason the picture also seems more sharper, however, Beelink is on top of their game when it comes to firmware support. However, the Beelink MXQ doesn't have a heatsink and sometimes it freezes completely, I think it is due to the heat.
My sister wants only Android on her machine, so if someone could please point me to a Android rom which has true 1080p for this unit, please do, would appreciate it very much. Thanks in advance.
Originally posted by MeleTest View PostI have tested it and the issue remains. Does somebody else have this message from dmesg when the usb stick is inserted?
[ 26.421821@0] usb 1-1.3: DVB: adapter 0 frontend 0 frequency 0 out of range (44250000..867250000)
Seems that problem is really with USB driver.
Originally posted by Haba View PostDo you know if the mk808b plus can handle 1080i mpeg4? The level of mpeg4 that Fios switched to for HD is not working on the Xbox 360 in Extender mode.
Originally posted by freezer2k View PostHi kszaq and everyone,
Awesome seeing how this project has developed. Even OE6 now
I kind of switched to using my FireTV more though, as I was watching quite some US TV-Series, that seem to be affected by this bug:
- 29.97 progressive videos stutter
I think this was more a generic AMLogic bug, right?
Any idea if and when this might get fixed?
Thanks,
freezer
Originally posted by mike808 View PostI just installed this version: OpenELEC-Amlogic.HD18Q.arm-5.0.8 on my new HD18Q all black box, however, my OK button in the middle is not working. I thought it was supposed to be fixed in OpenELEC-Amlogic.HD18Q.arm-5.0.8 this release of the firmware? Please help.
Edit: Sorry, I did not notice your posts on the next page. I'm glad you solved the remote control issue by yourself.For Android, you can try using SPMC by koying.
Remote works great now, only thing that doesn't work on the remote is the mouse mode, where you can control the cursor movement. I really don't use that much at the moment, however, it would be nice to have that work as well, for navigating through a video. I used SPMC with the Android machine however, because of the resolution screw up the video gets shrunked and is pushed towards the top left corner for the screen, I think this is because of the resolution mismatch between the Android upscaled resolution of 1080p and SPMC and other XBMC/Kodi builds detecting on 720p resolution. If someone can point me to a Android build for this unit that actually does true 1080p, I'm sure SPMC will work fine.
Guys, is there a way to install google play store in a rom that doesn't have it. I finally found a good Android based rom for this unit but, it wasn't rooted and it also doesn't have play store, however, I was able to root it using the s89root.zip but can't seem to install gapps file I downloaded from the net, It says it installs in recovery but, none of the playstore apps are visible.
Hello, first of all I stand and I appreciate the help.
My first question may be somewhat stupid, still have not received my mk808b + but from what I've read I think the first thing I'll do when I get is to install OpenELEC, I am very interested to use the TV remote via HDMI-CEC. The question is: can I install applications as youtube or can I just use KODI as mediaplayer ?.
Sorry if my English is not very good.
Seems that problem is really with USB driver.Originally posted by kszaq View PostI suppose you are getting this message with a "non-test" release? This is because of modified DVB core in Amlogic kernel. In the test version it has been reverted to stock but it still doesn't work properly.
Is there a way to backup gui settings in openelec? Reason is that I saved the .kodi folder and copied it over to the openelec configured machine. However, I had to set up all the gui shortcuts and everything over again. Is there a file or folder that you can backup to get the settings back how you set them up earlier?
For the price, it makes a great whole home DVR distribution. Not sure about mpeg4, never tried it. This stick is both a PVR server and client and never struggles. If you do decide to get this stick to tinker with, make sure you get the correct USB Ethernet adapter.
Edit: This is the Ethernet adapter that I purchased that works great for my MK808B+ , http://plugable.com/products/usb2-e1000. I had a couple of other Ethernet adapters, but they did not work very well.
I bought mine from Blinq for $15, but they are out of stock now.
Someone posted the Tronsmart USB Ethernet adapter used on the MK808b plus with Android is working, the spec sheet shows support for linux as well so I may give it a shot. I do not have any Mpeg-4 1080i files to test or upload, despite looking around on the web.
Originally posted by mike808 View PostRemote works great now, only thing that doesn't work on the remote is the mouse mode, where you can control the cursor movement. I really don't use that much at the moment, however, it would be nice to have that work as well, for navigating through a video.
Originally posted by sonnycrokkett View PostHello, first of all I stand and I appreciate the help.
Originally posted by MeleTest View PostKszaq, I am getting this message with the lastest test build
Originally posted by mike808 View PostIs there a way to backup gui settings in openelec? Reason is that I saved the .kodi folder and copied it over to the openelec configured machine. However, I had to set up all the gui shortcuts and everything over again. Is there a file or folder that you can backup to get the settings back how you set them up earlier?
There are currently 2221 users online. 0 members and 2221 guests.
