[ROM] Unofficial OpenELEC for MK808B+ and MXQ
I tried the micro sd card method, but when I start the MK808 Plus while holding in the reset button nothing happens. The google screen appears and that is it. I tried formatting the card in my phone, then I tried on the computer to get fat32. Still no luck. Am I missing something obvious? I have unzipped the package so that I have the 3 files on the sd card root.
Originally posted by Session^ View PostI tried the micro sd card method, but when I start the MK808 Plus while holding in the reset button nothing happens. The google screen appears and that is it. I tried formatting the card in my phone, then I tried on the computer to get fat32. Still no luck. Am I missing something obvious? I have unzipped the package so that I have the 3 files on the sd card root.
Originally posted by kszaq View PostI'm glad to hear that Bluetooth works as well.There are donations links in the first post, I recommend donating to Kodi and OpenELEC as thanks to their work we can have this great piece of software.
RTL8723BS WiFi didn't work with 5.0.8p14, with 5.0.8p15 it's reported to be fully working, except for BT which may start to work with the next release.
I am using a device tree from this release. I'm afraid I'd need to ask you to test multiple versions before we get to the solution as the patch that works with Beelink's MXQ doesn't work with HD18Q. I compiled another test build. Can I ask you to test it? Of course you don't have to reset your settings to factory defaults, an upgrade with no data wipe should always work.http://s805.eu/releases/test/hd18q_mac_test/
Thanks' a lot Kszaq. You have definitely nailed the MAC issue on HD18Q.
The only problem is that the true problem (I thought it was MAC related) has popped up.
For some reason HD18Q doesn't maintain a fix IP address. I can configure a fix IP, but after a reboot it is back on DHCP.
Arik
Originally posted by ArikZ View PostThanks' a lot Kszaq. You have definitely nailed the MAC issue on HD18Q.
Arik
As for the fixed IP address, I'll look into it in a few days, I need to find some spare time.
Originally posted by kszaq View PostI understand that the MAC address does not change with this test build? If yes, I will include the patch for HD18Q in all future builds.
Yes, the MAC does not change with the test build!
Awaiting for the resolution of the fix IP issue.
Thanks' a lot for your affords.
ArikZ.
Originally posted by kszaq View PostIf toothpick method doesn't work for you, you can issue a reboot to recovery command in Android (either using an app or over adb/terminal) and flash the OpenELEC-Amlogic-*-update.zip file. Remember to wipe data & cache when flashing manually for the first time.
Thanks. Is there a guide somewhere to get me started reading?
Hi I just receive a beelink mxq and installed your rom, and wanted to thanks you. Everything working out of the box so much better than the original android rom. I just got a few questions :
- Is tvheadend available on your rom as I would like to add a usb tv tuner later.
- You say to wipe data & cache when flashing manually for the first time, I miss this step and now the recovery doesn't propose this option anymore. What the benefit of wipe data & cache.
- One addon i really like is p2p stream but it is unable to play any stream on your rom. Does someone know if it's possible to run this addon on this platform.
Once again a big thank for your fantastic work.
Originally posted by Session^ View PostThanks. Is there a guide somewhere to get me started reading?
Originally posted by mac1202 View PostHi I just receive a beelink mxq and installed your rom, and wanted to thanks you. Everything working out of the box so much better than the original android rom. I just got a few questions :
Originally posted by mac1202 View Post- You say to wipe data & cache when flashing manually for the first time, I miss this step and now the recovery doesn't propose this option anymore. What the benefit of wipe data & cache.
Originally posted by mac1202 View Post- One addon i really like is p2p stream but it is unable to play any stream on your rom. Does someone know if it's possible to run this addon on this platform.
Originally posted by mac1202 View PostOnce again a big thank for your fantastic work.
Originally posted by override View PostHi, this openELEC port of yours is great, i have just one problem sometimes (most often than not) there is no audio output in 24p.
Originally posted by kszaq View PostWhich version and what device? Do you have passthrough enabled? You also need to provide me dmesg and kodi.log so I can see what's wrong.
Sometimes when i start movie or show there is a sound and sometimes no, then if i jump couple of seconds foward sound turn on.Last edited by override; 17 June 2015, 18:45.
Device is mk808b plus and version is 5.0.8 p15, passthrough disabled because when enable i dont get sound never on 24p, Here is kodi.log ( https://mega.nz/#!3U1y2ABa!2G3atjNP8...6Rn5NoLjc9hxjM) , i dont know how to get dmesg.
Originally posted by kszaq View PostPlease do. The test version has some changes to sound handling which brake sound output for some sampling frequencies, as I recently discovered. These will be reverted for the next release.
edit: sorry my bad i f.... up settings its all working now, thxLast edited by override; 19 June 2015, 22:41.
Originally posted by kszaq View PostIt is available in Unofficial Addons repo. Keep in mind that some tuners work well and some don't - if you want to purchase one, you should browse this thread for user reports or ask if anyone is using a specific tuner.
I'm interested by the AverMedia Volar Green HD tuner it's confirmed that it work with official openelec, will it also work with your build ?
There are currently 2231 users online. 0 members and 2231 guests.
