Chiptrip MXV S805 crashes network
    Glad to hear you got it resolved. It is good to see Gearbest is providing some customer support.
    Have fun!
      tks,I think that is the last firmware.. I disabled the digital signature in winfows 8 64bits , but the device isnt detected and the burning tool refuse to run, i execute as admin, but fails.. win7 mode xp-sp3 fails to exe crash....
      Originally posted by babis666 View Post
      UPDATE[/B]
      I asked help from Gearbest (where I purchased the machine) and within 2 days they send me the new firmware
      I flashed it and now I don't have the network problem , the machine seems to work flawlessly.
      EVERYTHING YOU NEED FOR UPDATING:
      1. OTG port is no.4
      2https://drive.google.com/file/d/0B_Ri-RWa0gGgcEpIaWIyVF93Yjg/edit"]. usb burning tool and drivers
      3. New firmware [/URL]update_S805_1G_zhongxing_20150615
      I hope this will help for anyone that has problems
        hi babis666,
        I did it...
        I use windows 8 - 64 bits, and the usb burning tool v2.0.4.3 provided by chinagadgetsreviews runs without crash
        and I follow this guide from chinagadgetsreviews and I used the updated rom image that you provided!
        http://chinagadgetsreviews.com/downl...-v2-0-4-3.html
        after flash the device, the device rebooted , and I installed king root apk... and now the root was done fine... (lol)...
        with the first rom the king root failed but now It worked with this updated rom image.. I don't know if the kingo
        support updated the tool ....
        now my device is finally rooted and adaway working like hell.. ;-)
        UPDATE
        1. OTG port is no.4
        2. usb burning tool and drivers
        3. New firmware
          Nice
          That's why I posted everything, to help my forum buddies
            Hi babis666,
            I am wondering how is the new firmware you installed? I am thinking also about upgrade but I am afraid that something will go bad. Have you tried to play videos and photos with KODI? Do you think everything is OK? With my current firmware version I have problem to find player for HD videos, all seem not to not play sharp (on desktop computer there si no problem). I tried KODI, VLC and MX Player with ARMv7 codec. Hope this new firmware can help. Thanks
              Hi tonny24, this is my machine after the update
                Thanks for the video. Have you noticed another improvements or downgrades of any features after upgrade (except that network is now working nice)?
                  I noticed Gearbest has this box on sale for $36.99(USD).
                  Do you Chiptrip owners think that is a good buy?
                  Thanks.
                    I have one of these boxes seems ok I did the update and everything seems to work. My only complaints are no true 1080p and they are not rooted but other than that ok
                    Cheers,
                    Vec
                      @RISCy Dude
                      Don't buy Cheaptrick brand, buy this instead:
                        For me it is great buy, it is my first TV box and I have got more than I expected. I use KODI as default launcher and everything works fluently. Just as I wrote before, video seem to be more pixelated in comparison to playing on PC, but it is hardly to recognize from distance of 3 metres.
                          Originally posted by csgabe View Post
                          @RISCy Dude
                          hink else like does it use
                          t
                          what brand is this box beelink?.............also are there firmware updates is it rooted and true 1080p? anything else you can tell us like does it use nand or emmc?
                          Thnx
                          Vec
                            @veclinux
                            what do you mean by "no true 1080p"? In the display settings it shows 1080p for me...
                              Originally posted by tonny24 View Post
                              @veclinux
                              look in system with kodi mine says 720 even tho the device says its 1080 means its using an overlay and not true 1080
                                I don't know if KODI upscaling to Full HD or the resolution changes after play 1080p. My KODI is also 720p. But if I use SPMC I have 1080p.
                                edit: According to this test KODI plays 1080p even if it shows 720p in settings
