    Hi Snoopy,
    u can use both of them for flashing,Batchtool for the one part Roms,and Androidtool for the splitted Versions and for one part Roms (second Tab).
    Hope it helps
    gefattern
      because we have some orbsmart s92 users (as i am too) here, could please give us one of the specialists here a little instruction, what exactly to do, thx a lot!
      how should we clean the device and how should we flash it?
        This is how I do it. Others have said there are easier ways. I haven't had a chance to try the "erase button" way yet that was suggested in this thread a few days ago. https://www.youtube.com/watch?v=K9lLJirKEIQ
        Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
          we cannot open the orbsmart s92 without destroying it ...
            I notice that it has problems on streeming chanels online again, on the 3.0.1 that problem was solved, I hope that Wasser will fix that, rest of the experiance very good, stable, fast.
              I try to flash new 3,02 but the result is the same .....
              Black TV screen and signal not supported ....
              I must know why!
              Wasser help me !
              Inviato dal mio ASUS_Z00AD utilizzando Tapatalk
                Hello again,
                we need step by step Instruction how to use androidtool for erase and finally flash wasser. Would be Great!
                Thx in Advance!
                Snoop
                  Originally posted by Snoopy12345 View Post
                  Hello again,
                  Thx in Advance!
                  Snoop
                  read through the first post....
                    Hello again,
                    Thx in Advance!
                    Snoop
                    You load up the android tool and choose the second tab 'Upgrade Firmware'
Name:	Android Tool 2.35_2.png
                    Click on the 'Firmware' button to browse and locate the image that you wish to flash.
                    You will also see the 'EraseFlash' button that you can use to erase your device.
                    I don't know how you manually reset an Orbsmart to get into bootloader mode ready to flash using the 'Upgrade' button but if you have a rooted device then you can do it from within Android by installed the Petrus Rebbot app from the Play Store (https://play.google.com/store/apps/d...s.reboot&hl=en)
                    When you have your flashing cable connected between the box and your PC, run the Reboot app and choose the option 'Reboot to Bootloader'
                    I am assuming that you have the correct drivers installed at this point and that your PC sees the box correctly, in which case the status of the Android tool will change to show that you have a connected and correctly recognised box.
                    Then use eraseflash, followed by upgrade.
                    You will see the status of the flashing in the window on the right and when complete the box will reboot and go through the process of completing the installation, which begins with a format of the internal storage.
                    The whole process should take no more than 10 minutes.
                      Hi Snoopy,first of all have you installed the RockchipDrivers on your Pc?
                      There is a Video in YT/how to flash Firmware on UT3 ,this would help and normally Wasser always has Flashinstructions in his Rom Folders.
                      Good luck
                      gefattern
                        What is the procedure to install wasser lolipop on sdcard?
                        I tried linuxium script, it works ok, but it seem the wasser hang on boot, having the WASSER word moving on screen indefinitely. ( I tried using loader 2.17 and also with loader 2.19 from wasser ROM)
                          Regretfully, Wassers LP does not support HD audio exit on a receiver. For TV box it is much more important than the existing support of ancient and primitive spdif.
                            That all depends on individual perspective.
                            Not everybody has a dedicated receiver and therefore SPDIF through the likes of a soundbar is quite sufficient for 5.1 and DTS passthrough.
                              [ATTACH=CONFIG]n534961[/ATTACH]
                              [ATTACH=CONFIG]n534962[/ATTACH]
                              Thank you all so far!
                              Bootloader mode is no problem. When i hit erase he want to go to Mask mode and the process interrupted. Upgrading is possible without problems. Erasing still not possible.
                              Snoop
                                That is true but if we are talking about BD ISO or mkv with high bitrate we can enjoy HD audio. Apropos Wassers Kitkates firmwares do it support.
