Inphic SPOT i5 S805 media Player
Originally posted by INPHIC - Jim View Post
Could you tell me your router brand and model?
Here is some info
https://www.insidegadgets.com/2015/0...er-dated-2014/
https://www.telstra.com.au/business-...de-r1-5071.pdf
On the above, dnla has been enabled
Originally posted by suttyom View PostI have a little problem. When i starting the Kodi application, the tv box is crashing, freezing. It needs a restart. You have any solution for this? First of all, I bought the box for using the Kodi. Thank you!
Trimis de pe al meu GT-I9301I folosind Tapatalk
Hi suttyom I have same problem, I test a lot of kodi versions and all firmwares, i ask to inphic here and they not answer any about this problem.
I don't own the i5, but as Kodi runs on other S805 devices, I think they will get this resolved.
Good luck
I gave this advice also in another thread check power. But beware when swapping. Check voltages and polarity are the same current can go up.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Again please inphic, on your remote mouse function, what key does emulate the right click function. eg, in Kodi/Genesis, if you have found a movie/tv show or whatever you like, you click it, and it will find all the sources of that show for you to select from. At that point, you can right click that menu, and a drop down list appears in Kodi that gives you more options. How do you do that right click on the supplied remote/mouse please?
edit...I have worked it out....the menu button acts as right click
I have also got another problem please.
Within KOdi, if it doing a download, and you walk away, and don't touch anything, the box must sense you are doing nothing, and turns itself off, stopping the download. This is no good, do others have the problem? In play mode all is ok, but no activity, it turns off...help pls...grrrr
Originally posted by viewer View PostAgain please inphic, on your remote mouse function, what key does emulate the right click function. eg, in Kodi/Genesis, if you have found a movie/tv show or whatever you like, you click it, and it will find all the sources of that show for you to select from. At that point, you can right click that menu, and a drop down list appears in Kodi that gives you more options. How do you do that right click on the supplied remote/mouse please?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 2833 users online. 0 members and 2833 guests.
