I get the Tronsmart MK908 beta android 4.2 firmware, uploading for you guys now
    I get the Tronsmart MK908 beta android 4.2 firmware,check it here:
    Please help test, and report .
    thanks
    Looking for developers
    Hello,
    thanks for uploading. I will try and test it in the evening.
    Hopefully the support for usb audio devices is working...
    I will report...
    Steffen
      Thanks been debating to get rid of this mk908.. I wont hold my breath but maybe this can save it!
      However i'm really looking for a 1080 output to rival my mk808 with finless ROM. I shall check it out now.
        Skype + Logitech c270 HD web cam fix?
        Logitech k400 + Logitech Wireless Mouse fix?
        Sixaxis app fix?
        Gameloft game fix?
        anyone tested these?
          The air mouse is smoother (Ipazzport). Only complaint is the big cursor. The skype is working with video and sound. Bluetooth is ok. External hardisk is ok. I will keep this rom at the moment.
            Good morning!
            Downloading it now to check it out!
              First test
              Hello,
              I've flashed the 4.2beta.
              positve:
              - usb audio devices are working
              negative:
              - bluetooth devices don't work (i see my bluetooth mouse and keyboard and i can pare to it but i don't get a connection, the bluetooth icon stays gray)
              - no 1080p
              - some of the pre-installed apps don't work
              Steffen
                Bluetooth ist ok?
                Hello bkling,
                what bluetooth devices did you checked?
                My mouse (i-tec) and my keyboard (speed link libera sl-7436-svwt) don't work.
                Steffen
                  Originally posted by sgei View Post
                  Hello bkling,
                  Steffen
                  I didn't check BT mouse and KB. I checked on audio BT.
                    Same problem for me. BT works and pairs to my mouse but the mouse does not work!
                    So BT has a bug for sure... I will see if I can fix that in my ROM.
                      So far im impressed its in the right direction, Speed is good, Mosue is smooth, My own apps respond well, and if the quote below comes true tomorrow Ill be a happy camper.
                      2 still 720p upscale, but factory will give me a 1080p kernel tomorrow for Tronsmart MK908 and you can flash to make it to 1080P
                        Wi Fi issues
                        WiFi speed drops to 5mbs real fast
                          Hmmm I am not having that problem. I have seen it before on MK808 dual cores but this is not happening to me.
                          Get the wifi analyzer app and try changing channels.
                            Thank You Bob, that seems to have solved the wifi issue. now if we could get back to a regular mouse pointer... Thank You!
                              I am almost done with this ROM but I cant get BT to work.
                              ONE TIME it popped up the usual pairing dialog and I entered my pairing code for my mouse which is just 0000. It worked then. But I cannot get it to work reliably. I am taking files from the T428 4.2.2 trying to fix it but no luck so far.
                              The mouse pointer is a "some like it" and "some do not".
                              Bottom line it is easily changed is framework-res.apk.
                              Not sure I want to change it. I did it once before and people complained!
                              Cant please all the people.
