leolas
overclocked kernel is here
Re: overclocked kernel is here
Originally posted by rceccleston View Post
Originally posted by rceccleston View PostThank you for your quick reply.
Will your final kernels support an ASIX USB Ethernet interface and AP6210 WiFi / Bluetooth modules?current devices(rockchip sucks)
Hardkernel ODROID C1 running android kitkat
Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
rPi model B+ running nothing ... bricked
Originally posted by Legitsu View PostVoltages and clockspeeds can be adjusted in the kernel
Originally posted by sam321 View Postfor only the old MK802-IV or UG007B or QC802
before I start just let me tell you that you are doing this at your own risk
I have been working on something this last day or so and now it is time to share it with everyone. This android stick suffers from a lack of good roms, there is only really neomode working on it. So I present to you a ported rom,all thanks go to the original author of this rom, I have just made it work on our sticks. This is the fastest android 4.2.2 rom that I have known, but the neomode rom is Very Good to.
the android version is android 4.2.2
original author of this rom is Finless
name of original rom " CX-919 4.2.2 - Finless ROM 1.4"
no known issues
what works
everything including bt and wifi
on first boot the screen may stay blank, do not unplug the stick, the recovery is working at this time setting up the system. Wait at least five minutes before unplugging the stick, but you should not have to do this
Replace The recovery with this one if it does not boot http://www.cloudstor.es/file/m1_NDg0Mw/
link to ported rom download here http://www.cloudstor.es/file/m1_NDgwOA/
So you are probably asking yourself how fast is it, well if you are lucky enough to use the overclocked gpu kernel this is what you will get
result ~17700 and details:
unfortunately 3D is still very very bad. Sam321 please, can You make kernel (1920 800 1600/1500) with +0.125 and maybe +0.25V for GPU or maybe also 1920 800 and hmmm 1200/1000 for ram? Because on kernel 1800cpu, 800gpu and 1400ram results are bit worst but 3d is unchanged ~2600. Regards!
So I have been working on fixing the HDMI Scaling on the android 4.1.1 rom, and I have just about fixed it. This was important to me as I do like this version of android better, at the moment I am finishing it off and then I will repack it, I should be finished in the next day or so as I want to get location services working
Originally posted by sam321 View PostSo I have been working on fixing the HDMI Scaling on the android 4.1.1 rom, and I have just about fixed it. This was important to me as I do like this version of android better, at the moment I am finishing it off and then I will repack it, I should be finished in the next day or so as I want to get location services working
Sam
Do you plan to make the rom for new version MK809III with AP6210.Anyother rom really not work well on my MK809III except stock rom, but stock rom can not be overclock at all.
So my modify for the fan ,heatsinks &case is stopped, the stick not used in the corner.Waiting for a good rom on new MK809III,and OC kernel for CPU&GPU.
HowardLast edited by Howard; 09 August 2013, 03:26.
Originally posted by sam321 View PostSo I have been working on fixing the HDMI Scaling on the android 4.1.1 rom, and I have just about fixed it. This was important to me as I do like this version of android better, at the moment I am finishing it off and then I will repack it, I should be finished in the next day or so as I want to get location services workingcurrent devices(rockchip sucks)
Help Requested - Unable to root/boot S400
Hi Sam and other Guruz,
Sorry to spam here but am a too crude noob could not request this elsewhere.. Could I please request you to guide me on how to do this..Sincere apologies once again to bother you all with this request..
I tried rooting my S400 MK809IV with RKbatch tool and now it does not detect my tv stick all. Here is what I did:
1. Downloaded Rkbatchtool V1.7 and did a hard reset to the tv stick
2. Then connected the stick to PC with USB and installed the tool drivers required (success till here).
3. Closed the RKbatchtool. Removed the USB from tv stick and after 5 seconds again connected.
4. Re-opened the batch tool and loaded the img file.
Hereafter, my device does not power up or is not detected at all. I tried with multiple ways and then stumbled across this forum. Hence, this request for your help please on how do I get my device up and running with superfast rooted images..
Thanking you in advance..
Warm regards,
- Humpty
no known issues
what works
you may need to crack open the device and short the NAND chip out and force it into mask-rom mode and then reflash the factory rom
you flashed the wrong rom on the wrong device
the S400 is a different board then the real Rikomagic MK809IV
people need to make it more clear that just because the Stick calls its self a MK809IV doesn't actually mean it iscurrent devices(rockchip sucks)
Originally posted by Legitsu View Postyou may need to crack open the device and short the NAND chip out and force it into mask-rom mode and then reflash the factory rom
I'll try that but am not sure how to do it..could you please help me with the same.. Also, I tried using original cozyswan S400 rom as well but the device goes undetected. Could you please help me on how to short the NAND chip? Thank you.
here is the method for the ug802
depending on the PCB used the two connections you need to short-out may be in a different locationcurrent devices(rockchip sucks)
Thank you Sir...will try this and get back to you..Thanks once again..
Originally posted by Legitsu View Posthttp://www.freaktab.com/showthread.p...o-flash-via-PC
I tried doing this but no luck. My board looks different. attached images as below:
Not sure if the Nand is below the black heat sync if I'm correct. btw, I managed to break my connector to the wifi antenna..Any suggestions please? Thanks.
Originally posted by humpty_dumpty_empty View PostThank you Sir...will try this and get back to you..Thanks once again..
There are currently 2083 users online. 1 members and 2082 guests.
