NEXBOX A95X Amlogic 905X FIRMWARE UPDATE 20160824
im getting something similar here on the 2/8 a95x i just added su apk and replaced the uboot .. and after upgrade i cant boot.. just ends up in recovery with the broken android logo.. do i need to delete the u-boot.bin.sd.bin & aml_sdc_burn.ini? thanks for all the help.. im new to editing firmware.. and im probably getting on everybodys nerves lol but thanks for sure
Originally posted by DONDIDIT View Postim getting something similar here on the 2/8 a95x i just added su apk and replaced the uboot .. and after upgrade i cant boot.. just ends up in recovery with the broken android logo.. do i need to delete the u-boot.bin.sd.bin & aml_sdc_burn.ini? thanks for all the help.. im new to editing firmware.. and im probably getting on everybodys nerves lol but thanks for sure
http://freaktab.com/forum/tv-player-...2-0-8-and-rootPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View Post
1. I used the boot files from Tanix TX5 Pro and replaced the boot files in stock firmware using customization tool. Get that firmware here: http://freaktab.com/forum/advertiser...mware-20160809
2. Per prahjister step, manually copied SuperSu.apk to C:\Program Files (x86)\Amlogic\CustomizationTool\tmp\level2\system\ app\(create folder"SuperSu")
3. Repack stock image and give it a good filename.
4. Load using USB Burning tool.
So, I don't think you need to mod the init.amlogic.board.rc as didn't need to. You could use the boot files in zip and SuperSu.apk that prahjister provided.
Give me a few minutes and I will test with prahjister steps.
Originally posted by J0hn View Post
DONDIDIT and prahjister For me, did not use the provided zipped file. Just followed steps provided by meatheadmike.
Give me a few minutes and I will test with prahjister steps.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Thank you for testing...i just provided the download to save a few steps and large download for the tanix firmware.
alriiiiightim in .. and it has root.. thanks again for all the help.. now i have one more problem.. and im wondering if theres more wrong with the firmware.. in kodi. whenever i enable live tv.. and turn on the siimple iptv pvr.. it completely disappears from the list.. then reappears disabled again.. as a matter of fact.. all of the pvr's do the same thing.. and ive tried 3 different versions of kodi to no avail
can anyone else test to see if its the same with theres?
Originally posted by DONDIDIT View Postalriiiiightim in .. and it has root.. thanks again for all the help.. now i have one more problem.. and im wondering if theres more wrong with the firmware.. in kodi. whenever i enable live tv.. and turn on the siimple iptv pvr.. it completely disappears from the list.. then reappears disabled again.. as a matter of fact.. all of the pvr's do the same thing.. and ive tried 3 different versions of kodi to no avail
There are currently 2471 users online. 29 members and 2442 guests.
Most users ever online was 7,737 at 15:33 on 01-16-2020.
