T428 Nexus Rom SDK2 and Multi-Windows - Official
Originally posted by mattman View PostThanks strauzo for the great rom. Seems to run the best on my T428 compared to other roms.
But I always keep coming back the nexus ROM. No ROM is perfect and the nexus one has its own quirks but, for me, out of the currently available ROMs, it is the one which best fits my needs.
Now, if Strauzo could just fix multi-disk mounting in the next version so that I could connect more than one USB storage at the same time, I would have no reason to even look elsewhere.Last edited by Molle; 16 August 2013, 18:44.
Just to report,
This rom also works A-mazing on the MK908 if you replace the kernel with an applicable kernel. You can find a few stable and well working kernels (i.e they play video properly) on this forum. replace modules also, although wifi and bluetooth work after replacing kernel without replacing modules. although my wifi stays connected until i need it. the moment an app needs some internetz, my wifi disconnects only to instantly reconnect and the cycle continues ad infinitum. maybe i have a junky power supply. i have a 3A sucker on the way, so we will see. i will also try replacing my modules for wifi and see if that does any good. otherwise, it works great. multiwindows is hard to use even with droidmote, but im getting the hang of it. i also install cheapcast since im using my tablet as a remote anyway, now i can shoot video from my tablet over to the TV as i see fit as well, then droidmote control the android tv also! any luck on anyone finding the SDK 2.0 multiwindow code sources out there? that would be the bees knees!
Originally posted by strauzo View Postin september for sure i want make an excellent rom also for mini x7Last edited by Molle; 17 August 2013, 17:53.
Guest
Originally posted by Molle View PostCurrently lewy20041's customisation of the latest Minix X7 firmware is the best-performing ROM available. I'm counting on you to pull some magic and surpass that with your version.
Not pure android = not compatible with many apps on google play and with google sdk.
All others rom are only stock chinese rom modificatins Nothing new.
The nexus rom have also the best video performances And is pure android.
What i thing about the pjAnderson kernel patch is:
This is not a correction but only a workaround in the kernel that reduce the video problem but create many others problems to the rom and instability on the kernel. Many usefull configuration , in rom development, can't be used if you have a kernel with this patch inside. This patch compromise also the future update of the manufactures.
The best solution for video problem is in the rom and work also with unmodified 720p and 1080p kernel.
The nexus rom have the best video performances on all players and also on xbmc and have an unmodified kernel.
For all other developers:
Why you use old rockchip stock rom as base if you can use sdk2 and also muktiwindows like me ?
On the nexus rom you can do all. Also hdmi zoom in / out
Is also the fastest rom. Test with antutu. but don't compare with overclocked kernel. You can burn your deviceLast edited by Guest; 18 August 2013, 08:55.
Strauzo, with all respect for your work, but Lewy's HFW 1.2.1 outperforms your Nexus in all aspects. Better streaming, smoother videoplayback and overall performance. Antutu 18900 in 720p and 17500 in 1080p with phja's ocl kernels. It does not have multiwindows, but who needs it anyways without touchscreen?
So try it yourself and see. The firmware tacken from minix7 is very good. And no "chinese" bugs for me so far...
With overclocked kernel and no extra cooling my T428 is the same temperature as with Nexus ROM.
Guest
Originally posted by BigND View PostStrauzo, with all respect for your work, but Lewy's HFW 1.2.1 outperforms your Nexus in all aspects. Better streaming, smoother videoplayback and overall performance. Antutu 18900 in 720p and 17500 in 1080p with phja's ocl kernels. It does not have multiwindows, but who needs it anyways without touchscreen?
Also a single core with 512mb ram can be better with good software. See raspberry pi with xbmc.
Video performances can't be better because on nexus rom is already perfect. And i read the kernel development thread. Do you read it ?
We don't need overclock To have all that works very well. Specially the video performances
Your sdk are old. Version one, nexus have sdk version 2 + multiwindows.
To test a rom there was many months, many are the possible scenarious. continue your tests in the meantime we enjoy with sdk2 and multiwindows and compatibility with all google play apps And with the best video performances.
P.s.
With droidmote in google play you can have all multi-touch functionality on every android hdmi sticks and i every app. You can use it Also for multi-windows on t428. Look the youtube link on top of this post.
Sorry but this is what i think.Last edited by Guest; 18 August 2013, 09:54.
Well, Nexus ROM was the best until Lewy's HFW came out. You can say anything you want, but I see the difference with my own eyes. HD video plays much better. And ethernet is way much faster. All I need is flawless playback of 720p and 1080p video over ethernet from my NAS. And in this HFW is much better than Nexus.
I don't need droidmote, Wi-Fi, webcams, bt, games, multiwindows and all other things. For me T428 is a plain LAN mediacenter.
Once again, 1080p kernel - it means true 1080p playback - over ethernet from NAS. Nexus ROM cannot play some heavy 1080p files, but HFW does it pretty good. Not perfect yet, but much better then NEXUS.
Guest
Originally posted by BigND View PostWell, Nexus ROM was the best until Lewy's HFW came out. You can say anything you want, but I see the difference with my own eyes. HD video plays much better. And ethernet is way much faster. All I need is flawless playback of 720p and 1080p video over ethernet from my NAS. And in this HFW is much better than Nexus.
But also only for your mediacenter purpose i suggest to use droidmote because is the best way to control your mediacenter from your couch. Many android media player have multitouch functionality. And is also good to have a fast mouse /keyboard when you don't want use a big hardware mouse /keyboard.
Different point of view. But for video performances for me the best is the nexus rom.
A standard kernel must be for sure better than a patched overclocked unstable kernel
When you will have problems with your rom get the Nexus rom to solve.
PS.
IF you want 1080p kernel on the nexus rom, download it from the first post of experimental firmware.
But i repeat you don't need 1080p kernel to see 1080p videos on your tv.
There are many tech documentation in internet to understand how android work.
I don't want convince you with this post. I try only to explain for other not tech users thar can be confused from post like your.
If an sdk1 rom is better than a sdk2 rom why rockchip have worked on it ?
But the best of the nexus is pure android not only sdk2.
Where you have tested this 1080p videos that work better on your rom ?
Every 1080p videos tested with mx media player on nexus rom work perfect.Last edited by Guest; 18 August 2013, 11:15.
Originally posted by strauzo View PostOk i understand now. You don't need the 98% of what can do an android hdmi sick.
PS.
There are currently 1891 users online. 1 members and 1890 guests.
