T428 Nexus Rom SDK2 and Multi-Windows - Official
AW: T428 Nexus Rom SDK2 and Multi-Windows - Official
Originally posted by marcelv View PostFinally I can see the whole of the screen, my scaling issue fixed
Thanks Sam... This solution made the Strauso ROM usable to me!
Guest
Originally posted by Maximus View PostThis is great. Is there a similar command to force the display in Horizontal mode all the time?
If you have problems long press on landscape in rotation locker app inside the rom. You have also in top right status bar "rotation lock"
Play with this setting in status bar and your device on every boot start in landscape.
Guest
Originally posted by finrodize View PostCould this file maybe be incorporated in the nexus rom? So that the screen scaling issue many of us experience would be gone?
After you press this button, every time your device start you have the best fit.
Originally posted by opengl1971 View PostI used the qube rom on my ug007b and to my surprise it booted , but my F10 air mouse
Or any other wirless mouse and keyboard doesn't work , i guess it is because the rom is
Pre-configured for touch controls , i can't modify anything because neither the mouse nor
The keyboard work , so can you please post the kernel configuration file or whatever makes
This rom read the F10 air mouse ?
Originally posted by strauzo View PostThe display is already in landscape for me every time i start my t428.
Originally posted by strauzo View PostAlso for me is perfet. Infact i use it as every day rom
We must only see how android 4.3 works on rk3188. For now we have already all that rockchip can update in future for other devices. Sdk2 and multiwindows.
But i'm happy of the very stable performanes of video playback 720p and 1080p in every media player and in all condictions.
But specially without overclock the kernel that can burn your device in so little space and without good heatsinks.
The problem of overclock is not only heatsinks, infact this devices already suffer of insufficient power, with overclock the problem is increased making the device unstable under some conditions.
We have also the best antutu score with a standard kernel.
This is only what strauzo think. And i respect the thoughts of others.
Guest
Originally posted by Maximus View PostStrauzo, this is not the case with MK908. Could it be the kernel that I am using that is causing this?
But i can't be sure. I don't have the mk908. I have only the T428 and should arrive a Minix x7 for the end of august.
I prefer work on devices with wifi / bluetooth chip AP6330, are more compatible with many tablets roms.
2 obstacles to adoption
1. My 2008-ish 32" Vizio can't shrink H-size or V-size enough to get picture to fit on screen.
2. Gotta have back function mapped to Right-click touchpad/mouse button
Somewhere in this thread there is a solution to the screen-scaling issue. I did indeed see something but no independent confirmation of functionality.
Anybody figured out how to get "back" mapped to Right-click?
With these two issues solved, I'd probably try this ROM again.
There's also the hide bottom bar thing. Most of Bob's ROMs have had great auto-hide features for the Bottom Bar. I've used the Hide-Bottom-Bar app for some other ROMs but it's a fussy annoying manual thing.
Well, at least, thanks to Strauzo there's something new happening for the T428. I thought it was going to be another Quad-core dust collector.
Re: T428 Nexus Rom SDK2 and Multi-Windows - Official
Originally posted by fwupow View Post1. My 2008-ish 32" Vizio can't shrink H-size or V-size enough to get picture to fit on screen.
I downloaded gmd auto hide which fixes the issue of the nav bar. It also corrected the aspect where the video in hbo go wasn't taking up the full screen.
Originally posted by ace9094 View PostHi Guys,
I have finally got XBMC working PERFECT !This roms is without a doubt 100% the best out for the T428
I have the following channels installed: (The ones with *** are tested and PERFECT)
Mash Up TV ***
IceFilms ***
1Channel ***
Discovery ***
SportsDevil (iGole.tv works, but not as good as Mash Up TV)
SportsAholic (Not Tested yet)
The Giddy Up Network (Not Tested yet)
Project Free TV (Not Tested yet)
Free Cable (Not Tested yet)
Hulu (Not Tested yet)
YOUTUBE LINK TO FOLLOW
If wanted I can upload my version of XBMC with channels added
Nowadays there are soo many flavours in
Go back on right-click
Originally posted by hochoch View PostSam321's fix does work great. I had to change the 95 to 92 since my tv over scales so much.
Do you know of any solution to the loss of "back" on the Right-Click buttons?
HDMI scaling
Originally posted by sam321 View PostSo how to fix the hdmi screen scaling. Ideally this should be done by changing the kernel source code , but as strauzo thinks that the GPL does not apply to him we will have to do it through init.d now you are probably thinking that this has been tried before and did not work.
Now we all know this does not work
echo xscale=95 yscale=95 > /sys/devices/virtual/display/display0.HDMI/scale
The question is why doesn't it, and the answer is simple, when I looked in the source code of the kernel I found that they had changed a few things, you see everything created in sys folder comes from the kernel, so now the correct line is
echo 95 > /sys/class/graphics/fb0/scale
and to easily scale down your display just download this http://www.cloudstor.es/file/m1_NDk0MQ/ and put it in system/etc/init.d and reboot
I would just like to add here that I believe that everything can be solved by working together and not against each other. when developers share information with each other things get fixed a lot faster, and means that you the end user gets a better experience
Now to deal with the upper status bar thing.
Right-Click = back
Originally posted by cityhunter View PostThis allows right click = back functionality by changing about 4 lines in Framework/base/services/input/inputreader.cpp by changing about 4 lines. Strauzo would you be interested in implementing this method of on future roms as this seems to be a legitimate way to implement the change without the need for closed source code?
EDIT: just noticed i completely forgot to include the link to the code:
http://stackoverflow.com/questions/1...-in-jelly-bean
Sounds dreamy! Guess I can't do this at home.
There are currently 3206 users online. 0 members and 3206 guests.
