deleted
T428 Nexus Rom SDK2 and Multi-Windows - Official
Webcam support
Hi Strauzo
I tried the soundabout app that you sugested and it did rerouted the mic to the webcam and the default camera app work for taking pictures, video and sound. But the thing is that when I try and use it with Skype or Hangouts it just simply does not bring any video on Hangaouts, the mic does work and Skype completly stops working when I make a video call. End result is that video conferencing is not working. Can you be kind enough to work out this situiation.
I realy love your Rom because I use HULU a lot and is the only ROM out there that support HULU or any other app on the play store. Hell I even use a vpn connection with you ROM. So for the most part evrything is working but skype and hangouts are missing something with your ROM for them to work. If you achive this, this will be 100% working rom. At least for what I use it for.
This skype/hangouts glitch has to be workable as I was able to use both with my webcams C170 and C270 with Finless ROM 1.5 on this same T428 stick.
Thanks for all your work.
Rdavidowski
Just got the mele f10 pro remote and the soundabout app switched the output between the remote and hdmi just fine, but my problem is with the mic.
I downloaded a sound recorder app and the mic records fine and its clear, but when I use an app like Skype, talkatone or viber the mic either doesn't work or the sounds comes out choppy, distorted or high pitched
On a side note, streaming google music to the remote and then to the attached headphones is very cool!
Guest
Rdavidowski
can you attach me some logcat when skype stop working ?
have you aleady tested with the kernel of Finless ROM 1.5, to see if it is a kernel problem or some files missing in the system img ?Last edited by Guest; 28 August 2013, 19:53.
Strauzo can I use this rom with mk802iv with its own kernel????
Sent from my GT-S7562 using Tapatalk 4 BetaFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Is there a way to permanently hide the multi-windows button without reverting to the default tablet ui?
Whenever I un-check the "Multi Window Buton Show" checkbox in the settings, it stays off for a while but then certain apps (mainly non-multi window enabled apps) cause it to pop back up again and when I look, the box for this setting is once again checked.Last edited by purplravioli; 03 September 2013, 21:13.
Originally posted by purplravioli View PostIs there a way to permanently hide the multi-windows button without reverting to the default tablet ui?
Originally posted by strauzo View Postthe problem is that i don't have this webcam to test on.
Well I flashed the multiwindow rom and no chance of booting on the mk802iv, just black screen. Is there anyone who has managed to run successfully this rom on mk802iv. Thx in advanvce
Sent from my GT-S7562 using Tapatalk 4FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
AW: T428 Nexus Rom SDK2 and Multi-Windows - Official
A question for those of you who use this rom with a cx-919. Which kernel do you use?
I have read that using kernels that have their own video stutter fix can cause trouble resp. Performance breakdown in conjunction with the nexus rom. So which one would you sugest?
Thanks in advance!
Gesendet von meinem GT-N8013 mit Tapatalk 2
Originally posted by finrodize View PostA question for those of you who use this rom with a cx-919. Which kernel do you use?
Thanks in advance!
There are currently 3218 users online. 0 members and 3218 guests.
