[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Originally posted by Dynamitis View PostThe upgrade is in h96+pro. May be that the fault?
Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
You need to get to remote.conf file from original firmware in order to get it work.
It has been highlight before if you are using Beelink firmware on H96pro or plus.
Originally posted by muncheno
Yes, that is the problem.
Originally posted by Dynamitis View PostThank you very much for your answer. Is there any place how to find and install it?
If not manually extract the remote.conf file to right location and set the correct permission.
H96pro.Remote.UPD.zip
superceleron are you working on a version of Android TV Nougat or should I use these ROM instead => http://freaktab.com/forum/tv-player-...android-tv-7-1
Originally posted by Jive View Postsuperceleron are you working on a version of Android TV Nougat or should I use these ROM instead => http://freaktab.com/forum/tv-player-...android-tv-7-1
That rom you pointed out is for the GT1 not the GT1 Ultimate!
Nop, i said im not doing 2 type of roms for one box again, i dont have the time to do so!
Anyway, I've tried tout install stock ROM 7.1.1 but I didn't manage to use Amlogic USB tools, it always boots on TWRP. And with TWRP, I don't know on which partition I have to install the img file (logo, recovery or bootloader). Tried bootloader, but it says there is not enough space on that partition. Any advice ?
But some sais they've installed it on GT1 ultimate and it works.
Originally posted by Ducati_996sps View PostYour best bet is to install superceleron rom its perfect
Originally posted by Ducati_996spsYour best bet is to install superceleron rom its perfectOriginally posted by dm15hello
I used the method with the SD card. 1 put the rom scv1 on a micro sd, Plug in the mains while pressing under the box with a paperclip .wait for the rom to settle!switch of a box. 2 put the rom scv2 on the micro sd. start the box. go on the recovery, search rom in micro sd card and go .
Sent from my SM-G935W8 using Tapatalk
I've already installed Superceleron rom, but I need Android 7 to use a USB TV tunner with Live Channels (not available with Android 6). So I'm trying to install the ROM given by Beelink on Freaktab, but I'm stuck with TWRP.
I was wondering : to uninstall SC ATV ROM and get back to the stock ROM, should I replace the recovery partition with stock recovery (with TWRP) and then reboot and install stock ROM with USB or SD card method. Is it dangerous to do so, I mean only changing recovery partition ??
Originally posted by laboss View PostHello ppl, i got a Beelink GT1 Ultimate and I am trying to flash to SCV1-ATV-GT1_Ultimate, but I'm not getting it, by the SD Card method the box gets blocked at "UPGRADING" screen by USB Burnnig get error in image ...
The box have the G912 serial, it came from the factory with the firmware 703N0 Android 7.1.2
There are currently 2937 users online. 1 members and 2936 guests.
