Tronsmart MK908 WiFI problem
    Hello!
    I have a problem with the connection by WiFi to the device Tronsmart MK-908. Device not connecting to my access point if has other access point with better signal level.
    Conducted an experiment, turned on the access point on the smartphone Samsung Galaxy S, situated in the same
    room with the device connected, everything works. SGS began to distance from the device as soon as the signal from SGS has
    become smaller neighbor's access point, the device is turned off happily from my point of access, hid it in the list, and it was hinted that there is a better signal. Brought SGS, the device immediately acceded to it and keeps the connection.
    That is, In my view, there is a defect in the firmware, the producers decided that any access point to the level of the signal is better preserved than the best for me.
    We must somehow make an appeal to the producers, can fix how to do it, someone tell me?
    Regards, Konstantin
    Yes - Throw Away the Stock Rom
    Originally posted by constv View Post
    Hello!
    Regards, Konstantin
    Best wifi for the 908 that I currently know of is obtained using Finless T428 Alpha Test with the kernel from Finless 1.4 for the 908.
    Also got excellent results using Finless CX 919 4.2.2 with the kernel from Finless 1.5 for the 908.
    Video is also much smoother than stock. Not as smooth as with Strauzo's 908 kernel but that one tends to throttle wifi.
      finless 1.5 flashed the firmware and kernel strauzo, connected to the access point and keep the connection was, but if you connect a wireless keyboard, wifi falls off.
      if you turn off the radio keyboard, the speed of both the dial-up in the 90's, rkremotecontrol can not use it terribly slow, spend your finger and the cursor still for a minute moves across the screen.
      My conclusion - this is not a wireless device, it can be used for wireless access to the Internet via wifi, perhaps, only in ideal conditions.
      wanted to give asus o'play mini plus (which works with wifi in the same conditions normally, dvd-9 plays no lag) parents, but now think about it yet. sorry for bad english
