[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by kolsysI prepared a patch for solving the problem with activating wi-fi after the sleep mode in the latest firmware.
The patch sets the lock_me flag to /sys/power/wake_lock on boot.
I use it with HDMI-CEC power off and It's work good.
Installation via TWRP.
Can you fix the Ethernet connection too?
update.now got my m8s pro 2gb/16gb with drm l1.installed am3 atv modded firmware but check with drm info says l3 support.so firmware missing some relevant info to allow l1 to work.l1 is still present on box.so firmware needs changing to work correctly.put Magendanz latest version on and got Netflix hd with 5.1 sound.so widevine L1 working ok.also Bluetooth remote works as well.Last edited by supermal; 20 June 2018, 19:00.
Hi everyone and thanks for this update. I installed OTA UPDATE (531MB ZIP file) update_M8S_PRO-V0928_TVStock-20180310.zip via local update erasing all data and everything worked fine all up and running perfect. However I installed Terrarium Tv apk and it works ok but after watching something for approximately 45 minutes the box freezes. The screen freezes and sound freezes and the only way to do anything is to unplug box and start it up again. Has anyone else experienced this issue and how do I resolve it. Thanks for any help offered.
Originally posted by wigam1981Hi everyone and thanks for this update. I installed OTA UPDATE (531MB ZIP file) update_M8S_PRO-V0928_TVStock-20180310.zip via local update erasing all data and everything worked fine all up and running perfect. However I installed Terrarium Tv apk and it works ok but after watching something for approximately 45 minutes the box freezes. The screen freezes and sound freezes and the only way to do anything is to unplug box and start it up again. Has anyone else experienced this issue and how do I resolve it. Thanks for any help offered.
I'm having a problem with netflix, I was using the factory version of mecool m8s pro + and from one day to the other netflix stopped working, even with it coming back several times to the factory settings and youtube started to have some specific errors also, I did the update via OTA for this rom nexus 7.1.2, the youtube error was solved however the netflix does not work no matter what version I download, it does not appear in the playstore anymore and some versions lock in the word "Netflix" others do not even get to that part and soon the app stops responding ... Somebody help me!
Originally posted by luscas27 View PostI'm having a problem with netflix, I was using the factory version of mecool m8s pro + and from one day to the other netflix stopped working, even with it coming back several times to the factory settings and youtube started to have some specific errors also, I did the update via OTA for this rom nexus 7.1.2, the youtube error was solved however the netflix does not work no matter what version I download, it does not appear in the playstore anymore and some versions lock in the word "Netflix" others do not even get to that part and soon the app stops responding ... Somebody help me!
Did you do a clean install, with all wipes?
Originally posted by luscas27 View PostI'm having a problem with netflix, I was using the factory version of mecool m8s pro + and from one day to the other netflix stopped working, even with it coming back several times to the factory settings and youtube started to have some specific errors also, I did the update via OTA for this rom nexus 7.1.2, the youtube error was solved however the netflix does not work no matter what version I download, it does not appear in the playstore anymore and some versions lock in the word "Netflix" others do not even get to that part and soon the app stops responding ... Somebody help me!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2597 users online. 2 members and 2595 guests.
