Magendanz.. I have one question for you about Android Pad/Keyboard on android games. I bought a keyboard for the tv box- two different models: iPazzPort KP - 810 - 21S and TZ P9 Wireless Mini Keyboard. Is there any way for android to recognize these keyboards as pad/android pad in android games?Last edited by essir; 11-18-2017, 06:59.
How do you install TWRP ?
can i go back and forth flashing stock image and custom with it ? I see you mention you are working on solution to have the update on rom itself like in the stock will this be able o flash back and forth with stock ? also sometimes when i go into settings for resolution noting happens then other times it works , i been using this rom past for days not had any issues even wifi is very good only issue is the google search error but you say will be fixed next release
#1217.1Guest commented11-18-2017, 02:50Editing a commentUnfortunately, VideoStrong has a bug in their update script that prevents it from installing in TWRP. You may have noticed that I've posted versions of the stock OTA (with"-fixed" appended to the filename) that have corrected this issue. Otherwise, you should be able to pop back and forth between OEM and custom ROMs. Note that the OEM update will reinstall stock recovery, so you'll lose TWRP.
Need some help
Got my new mecool Device today with latest stock ROM and without reset switch.
Installed this Custom Rom today. But had Problems with Amazon Prime Video.
Now I want to go back to Stock ROM.
Burntool does not recognize the device because there is no reset switch
startet TWRP with Terminal Emulation "reboot recovery" - but it stops with Error 7 : This package is for "M8S_PRO_PLUS" devices; this is a "p21x"
edit: finally flashed with Burntool. Opened the device and shortened the holes where the reset switch should be...
See note above about OEM update script issue. You should check here for fixed versions: http://freaktab.org/27~f
Thanks ! It´s always the same for me : long Threads, English not my mother tongue. So I tried for hours because I didn´t see the solution..
I am using the Nano Version of your ROM now and I really like it.
Amazon Prime Video didn´t work in AndroidTV Versions. Video crashed or a Video can´t be played Message.
But its ok in Nano Version.
So I have pretty much physically killed my Mecool box in an effort to reduce temperatures
Basically I think that the S905 chip has a bad solder joint. If I put physical pressure on the heatsink / chip it works fine, but as soon as that pressure disappears it will either display nothing, or heavy artifacts / glitches
So now I have wedged a piece of foam between the heatsink and the top of the case....
I was trying to reduce temperatures to below 80 C. And if you think your box runs below 80 C under load, think again..
Using an app called "Stress CPU" you can properly test the max termperature the box will reach https://play.google.com/store/apps/d...enix.stresscpu
Unfortunately, I did not test this with the stock heatsink but as you will see in the following images, the replacement heatsink is about 5x bigger. Yet it could not keep the temperature below 80C for much more than 5 minutes.
Here goes.
Originally posted by Magendanz View PostNope, wireless performance should be exactly the same as with the stock OEM firmware, since I haven't made any changes to the wireless configuration. These boxes have really cheap internal antennas, and there's really not a lot we can do about that in the firmware.
Originally posted by 4everAnoob View PostSo I have pretty much physically killed my Mecool box in an effort to reduce temperatures
Here goes.
Originally posted by mirbg View Post
I just changed the channel for 5GHz of my router to "40" and this "crappy" wifi flies on 130Mbps now I advice everyone to do the same, I have never experienced better wifi on any tv boxes I have tried...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
anyway stock rom i see it was connected at 72mb in router firmware with custom rom its at 150mb now and getting higher speedtests havent changed anything else other then the rom
Hi Magendanz and friends, I know this is a half-beaten theme, but I'd like your guidance to identify if my new M8S Pro + comes from a defective batch. I would like to know if there is an app to check this or if just opening it?
There are currently 10328 users online. 8 members and 10320 guests.
