cx-919 custom HFW mk908 1.1.2 1080p rom by lewy
In order for it to work on the cx-919 you have to go here: http://www.freaktab.com/showthread.p...ybrid+Firmware comment 19 details how to do it, use finless 4.2 rom package in place of t428.I also used the stock 1080p kernel found here: http://www.freaktab.com/showthread.p...-stock-kernels. wifi and Bluetooth work very well.Tags: None
Originally posted by bloatman View PostIn order for it to work on the cx-919 you have to go here: http://www.freaktab.com/showthread.p...ybrid+Firmware comment 19 details how to do it, use finless 4.2 rom package in place of t428.I also used the stock 1080p kernel found here: http://www.freaktab.com/showthread.p...-stock-kernels. wifi and Bluetooth work very well.
Originally posted by AlbaJoe View PostThanks for the links bloatman. How is Netflix and XMBC on these?
You guys are next on my list for a 1.5 ROM using the same base that Lewy used for the 908 ROM.
Stay tuned I will have you something soon!
Originally posted by Finless View PostYou guys are next on my list for a 1.5 ROM using the same base that Lewy used for the 908 ROM.
Thanks Bob
Bob.
My 2cents worth - like many others, my use scenario is mainly for XBMC; I've been holding off for a ROM that gives a reasonable XBMC (~nightly) experience (internal player working, AV sync, no frame dropping) without too many end-user work-arounds (swapping out kernels, tweaking resolution code, etc). Getting these functions working at 720p would be excellent (for me, 1080p would be a 'bonus').
Thanks for your heroic endeavours!
Originally posted by maxH View PostHey Bob - great, really appreciate your efforts.
to sum it up, bob is the man
BobPlease consider making a Donation to freakTab
There are currently 1956 users online. 0 members and 1956 guests.
