MECOOL K6 DVB S2 - T2 - C TV Box
    Huawei HiSilicon / 2GB RAM + 16GB ROM / 2.4G + 5G WiFi / USB3.0 / BT4.1 / 100Mbps / 4K VP9
    Main Features
    ● Android 7.0 operation system
    ● Hisilicon HI3798M CPU, Quad core, ARM Cortex-A53
    ● Mali-450 GPU, Penta-core, 750MHz
    ● 2GB DDR3 RAM + 16GB ROM
    ● 2.4GHz + 5GHz dual band WiFi
    ● 100Mbps Ethernet
    ● Support 4K ultra HD image display
    ● Support H.265 decoding
    GEARBEST
    Does anyone know how to access the cccam menu on this box? The 6*1 on the DVB S2 menu doesn't seem to be working on this box like in the other mecool hybrids.
      Mecool K6 cccam Will work beautifully after installing the APK in the link below
      Http://t.me/mecoolk6
      Discussion group for Mecool K6
      Jgon
      Junior Member
        What link?
        Enviado do meu Mi A2 atrav?s do Tapatalk
          Originally posted by grelhal.rui View Post
          What link?
          Mecool K6
          Mecool K6 dedicated discussion group.
          https://t.me/mecoolk6
            Hi
            Can you share main board picture of this Box ..what version /type tuner is installed in This
            regards
            Raza
              Originally posted by raza05 View Post
              Hi
              regards
              Raza
              Don't buy this box! The Hisilicon HI3798M isan old cpu chip already, the chip has two versions the high-performance version that comes with the Mali-T720 GPU and then this budget version with the Mali-450 GPU. Mecool could have went with the better chip but they like to sell crap cheap boxes.
                I know Just want to see the main board & tuner by myself
