Help unbrick H96Pro +
    Hi all. New member with very first post seeking some help. After hours of headache trying to unbrick unsuccessfully my H96 Pro plus and getting error message I learned this is due to "License File".
    Please someone HELP to get me bring my unit back as it connects to USB burning tool but does not let me install a firmware update.
    REVISED:
    I have H96 Pro plus (3+32/9377) unit with CZ-S32-V6 sticker on board.
    Unfortunately it got bricked while trying to upgrade using SD card but it was able to CONNECT with USB burning tool but would not update giving "Get key error".
    I may be in a BIGGER doo doo now.
    I used license key folder from a USB burning tool 2.06 to v2.08 and with one ot two errors, successfully completed installing one of the ram. But it remained bricked.
    Now it does not remain CONNECTED for than few seconds. Trying to upgrade to any another image is returning with following error message.
    "[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result"
    Please HELP.
    Originally posted by hryder View Post
    Hi all. New member with very first post seeking some help. After hours of headache trying to unbrick unsuccessfully my H96 Pro plus and getting error message I learned this is dur to "License File".
    Hi ,
    more Info about Problem you need LicenceFile for Flashtool or what ??? ,
    User "Scooter" can help with that , but you can find Infos here too , you only
    have to search , and why you not use one of the CustomRoms for your Box ,
    to find here too , but REMEMBER your Box exist in differnt PCB Versions ,
    so if , always , read & ask in the specific Thread if compatible ,
    greetings / gefattern
      Hi ,
      have to search ,
      I am getting "Get key failed" error.
        Hi ,
        write a PM to User Scooter , he can guide you to the Solution ,
          Hi ,
          I will right after this post.
          I used license key folder from a USB burning tool 2.06 to v2.08 and with one ot two successfully completed installing one of the ram. But it remained bricked.
          Please HELP.
            Please HELP.
            Hi ,
            why ??? , please if you need help , do nothing stupid , take the Time , think you have the wrong Rom ,
            please open your Box and check what RAM is used DDR3 or DDR4 , look for Superclerons Rom that
            works with both types of RAM , best to post Pictures of both sides , nearby , good light & clear ,
            you can change the Header of your Thread to "Help unbrick H96Pro +" this will get more response ,
            and ask Scooter for help with your Licence Problem , or guide you to a direct working Flashtool ,
            uninstall it (reboot PC) and use the good one ,
              Hi ,
              nice , the only Rom you can try is from Superceleron for both RAM types & Wifichip ,
              you can ask in Superceleron Rom Thread too , but not always making new Threads
              for same Problem , not needed ,
              maybe your mixed Flashtool makes it not possible to connect , better uninstall and use
              a working one , but i think you must "shortPins" for good connection to PC , i am sure the
              Infos you need are here , other Users had to do it too on H96Pro+ ,
              good luck / gefattern
                Hi ,
                I was able to make stable connection shorting pin and downloaded the following rom for CZ-S32-V6 from;
                The rom was aml_7.1.2_s912_q9377-S912_LP_mac-20180409.img
                the unit powers on now ONLY with USB connected.including program screen WIth power inserted, remains no video while blue lights are on.
                  Hi ,
                  first Link , many useful Threads , second Link Rom of Superceleron
                  that hopefully fits for you , but best before you do anything is / read
                  the Rom Thread (second Link) , & other helpful Threads too ,
                  EDIT: One more update... Many Thks to my beta tester's trebor and scooter2014 ! READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!! UPDATE LIKE THIS - SCV4 (IMG) -> SCV7A (OTA) (ALL OTHERS THAT ARE ON OTHER VERSIONS YOU CAN UPDATE JUST FINE ) ON IMG INSTALL CHECK IF YOU PCB IS BLUE (LPDDR3 PRINTED ON THE BOARD) OR GREEN
                  hope you find a fix , further good luck / gefattern
                    Hi ,
                    Downloaded
                    OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus.zip
                    It has 4 image files. None can be parsed by the USB burning tool. How to install the firmware?
                      Downloaded
                      Hi ,
                      listen maybe you can install it over SDCard , but better would be to ask once for help in the Rom Thread
                      and explain what exactly happend , maybe some Pictures of PCB , if possible , because i am not really a
                      AML Pro , i can only try to guide the Users in the right Direction ,
                        go to folder H96 Pro+ Firmware Fixed Uboot Power On Libreel
                        od the END of FOLDER NAME
                        v3 is normal DDR3
                        v6 is a LPDDR3
                        instal IT by cable
                        PS all LPDDR3 roms have LP in name )
                        i need to try to make STOCK-> add TWRP+ fix uboot + v6 becous on v6 i have problem witch instaling TWRP
