New firmware android 9.0 for Amlogic S905x
Originally posted by sugiputra View Posti have take apart the machine of the box, wifi and bluetooth is one chip, wifi work but bluetooth not working, i don't know how to improve the firmware..
Originally posted by sagert View Post
Unfortunatelly me too.I found firmware android 9 for s905x.Maybe someone will do it.But there is probably nothing new.The same core with the same drivers.
https://chinagadgetsreviews.com/down...m8-tv-box.html
what the solution, sir?
Okay, with this fw my tv box at the first scanning for bluetooth remote, and i try to pair with my remote no device found, but if i try to scan using my phone tvbox and remote, bluetooth appear. so i can pair it and i can't enter the menu just stuck in scanning remote
Hi , I have a z69 3gb but keep running into the problem of the usb burn tool failing to install the dtbo partition on Android 9 ROMs and stopping at 10% I assume this has something to do with my dtb file and creating partition tables can anybody suggest what I need to do to fix this problem ..thanks in advance
Originally posted by jimennis View PostHi , I have a z69 3gb but keep running into the problem of the usb burn tool failing to install the dtbo partition on Android 9 ROMs and stopping at 10% I assume this has something to do with my dtb file and creating partition tables can anybody suggest what I need to do to fix this problem ..thanks in advance
Originally posted by mick154 View PostFixed Bluetooth for rt8723b
Added magicsee launcher
added es file explorer, chrome
Changed Tvsettings
?????this works fine for me on my m9s pro
use at your own riisk
https://mega.nz/#!Rcxz0QrT!fD0pi8f0S...6nvaLjEz6_HLHI
I dont have S905x devices anymore, maybe someone could try to replace system.partition by one from ATV9 !
Thanks sagert , below is a link to the firmware and log any help would be appreciated . I think the problem is the creation of the correct partitions but not sure .It happens on any rom i use as i have to include my boxes original dtb partition otherwise the flash will never start.
2020.03.06-13.txt
https://1drv.ms/u/s!Agb_Eksj64MtpXSl...dFCvO?e=fr71lu
Attached FilesLast edited by jimennis; 03-06-2020, 22:12.
Originally posted by jimennis View PostThanks sagert , below is a link to the firmware and log any help would be appreciated . I think the problem is the creation of the correct partitions but not sure .It happens on any rom i use as i have to include my boxes original dtb partition otherwise the flash will never start.
2020.03.06-13.txt
In your journal it says that UBT cannot write dtb.PARTITION.Maybe it is more than necessary.It corresponds to the size in the log with dtbo.PARTITION .With it, it is necessary to work on it stop.Can replace it with another with 1kb. With another firmware.There are more ideas for 5p0ng3b0b.Here
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x3/firmware-roms-tools-ds/794463-rom-generic-sc-v2-0-user-userdebug-s905x2-s905x3-androidtv-build/page10
He invented something.
dtb_extract.zip
Can who else will tell you.
2020.03.06-13.txt
Can someone please guide me with this post of mine?
New firmware android 9.0 for Amlogic S905x. Firmware address : https://mega.nz/#!b0cCSIYS!-9ML4KocxP3iWAEsujNq7g1mSeCuhV_nIs7-UQ0KfeI I write English with translation. Therefore, I will be laconic. Write your feedback. I made this firmware as a port.
Thank you all in advance
There are currently 8931 users online. 7 members and 8924 guests.
