New firmware android 9.0 for Amlogic S905x
Originally posted by minonano View Post
just4survey1 , yes I did install them both, but for different boxes, if you read ealier you would note that the pro is for 2GB while the other is for 1GB ram, so which one is yours and which chip is your Wifi??? And yes in my opinion ATV9 is much faster than 7.
Originally posted by minonano View Postjust4survey1 , yes I did install them both, but for different boxes, if you read ealier you would note that the pro is for 2GB while the other is for 1GB ram, so which one is yours and which chip is your Wifi??? And yes in my opinion ATV9 is much faster than 7.
Any instructions how?,, Thanks ?
You also need to unpack boot and recovery and insert the new dtb into boot and recovery.This can be done using the AIK from osmosis XDA.There the boot.img-second file changes to dtb in the boot file.There the recovery.img-second file on dtb changes to recovery.I hope you figure it out.Then insert these 3 new files _amp_dtb.PARTITION , boot.PARTITION , recovery.PARTITION into the new firmware and make it.And sew it.It's certainly difficult.
Originally posted by minonano View Postsagert , thanks for the help. I was hoping to simply copy the files from the stock rom( Bluetooth working but not ATV ) to Daivietpda tx5pro (ATV9 but no bluetooth), from vendor/etc/bluetooth. But bluetooth did not work, too bad that would have been much more simple.
There are currently 8643 users online. 6 members and 8637 guests.
