Huge update to base build system:
- All Amlogic devices now use the same kernel 4.9-19!
- You might notice a bit more performance on some emulators as well usage in general.
- IMPORTANT: S905 (GXBB, p201) for the moment is no longer supported. If you have one of those devices (s905 no letter after the 5) DO NOT UPDATE, stay in 4.3.
As always. while we try to test every aspect of this release with many new settings, options, emulators and ports it is impossible to test it on all devices and with all games. If you find any issue please use Discord, The EmuELEC forum or if you are sure its a reproducible bug open a GitHub issue.
