H96 MAX V58 Android 12 RK3588 4GB/32GB TV BOX WIFI6 Gigabit LAN 8K Decode
  • H96 MAX V58 Android 12 RK3588 4GB/32GB TV BOX WIFI6 Gigabit LAN 8K Decode
    Avi Image Support
    Avi is an image codec similar to PNG and JPEG. It guarantees the same quality as JPEG, but with a significantly reduced file size. It uses the AV1 codec originally introduced in Android 10.
    Project Mainline Improvements
    Google announced that the art will be incorporated into the mainline of the project, available for download through the Google Play Store. Other modules are also being added.
    Application Optimization
    Other app optimizations include Google preventing background programs from starting foreground services. Latency and task assignments also change, which can improve performance.
    Multi-channel Audio
    Android 12 now supports mpeg-h passthrough and offload. The total number of channels for mixers, resamplers and effects is now up to 24.
    8K Decoding
    8K provides a higher resolution, which also means that the 8K H96 MAX TV box can display pictures with more information, whether it is fonts, character skins or the details of objects on the pictures will be displayed more clearly.
    WiFi6 and Gigabit Ethernet Port
    H96Max V58 supports Gigabit Ethernet port, which means that you can enjoy ultra-fast file download and transfer speed while ensuring the stability of download. What's in the box?
    1 x H96 MAX V58 TV Box
    1 x HDMI Cable
    1 x Remote
    1 x User Manual
      Posting comments is disabled.
    Categories
    Article Tags
    Latest Articles
