MK 802 III brick after trying to change from 1.8 Fineless for UG
    Saw similar threads around but didn't find solution... I flashed to my MK 802 III (not S) Finless 1.8 for UG, it works but I saw that RM released new FW for my stick. When I tried to flash new I got error in Batch Tool (similar to the following, this log is last from endless attempts):
    Code:
    23:38:57 667    Rockchip Batch Tool v1.7.1.1 start run
    23:39:58 601    **********Upgrade Start Total<1>**********
    23:39:58 616    <Layer 1-1-2> Test Device Start
    23:39:58 616    <Layer 1-1-2> Test Device Success
    23:39:58 632    <Layer 1-1-2> Check Chip Start
    23:39:58 632    <Layer 1-1-2> Check Chip Success
    23:39:58 632    <Layer 1-1-2> Get FlashInfo Start
    23:39:58 647    <LAYER 1-1-2> INFO:FlashInfo: 0 0 0 1 0 10 10 28 20 4 1
    23:39:58 647    <Layer 1-1-2> Get FlashInfo Success
    23:39:58 647    <Layer 1-1-2> Prepare IDB Start
    23:39:58 647    <LAYER 1-1-2> INFO:CS(1)        (8192MB)        (MICRON)
    23:39:58 881    <LAYER 1-1-2> INFO:FindBackupBuffer-->No Found Tag
    23:39:58 897    <LAYER 1-1-2> INFO:FindBackupBuffer-->No Found Tag
    23:39:58 897    <LAYER 1-1-2> ERROR:PrepareIDB-->Loader-->No Found IDB
    23:39:58 913    <Layer 1-1-2> Prepare IDB Fail
    23:39:58 913    **********Upgrade Done Success<0> Fail<1> Time<312>ms**********
    ROM Flash Tool doesn't help to flash Finless 1.8 back:
    Code:
    23:42:10 780    Load Setting ok
    23:42:10 936    Finless ROM Flash Tool - RKAndroidTool v1.3.5.0 Start Run
    23:42:10 936    Scan thread:1740
    23:42:10 951    ProcessID:1760,ThreadID:4320,RefCount:0
    23:42:10 951    ProcessID:1760,ThreadID:1740,RefCount:0
    23:42:10 967    Info:(thread=1496)IoControlProc-->DeviceIoControl In
    23:42:10 967    Info:(thread=1496)IoControlProc-->DeviceIoControl Out,ret=1,err=183
    23:42:10 998    Info:(thread=5320)IoControlProc-->DeviceIoControl In
    23:42:10 998    Info:(thread=5320)IoControlProc-->DeviceIoControl Out,ret=1,err=183
    23:42:11 029    Info:(thread=3384)IoControlProc-->DeviceIoControl In
    23:42:11 029    Info:(thread=3384)IoControlProc-->DeviceIoControl Out,ret=1,err=183
    23:42:11 029    Info:(thread=700)IoControlProc-->DeviceIoControl In
    23:42:11 232    Info:(thread=700)IoControlProc-->DeviceIoControl Out,ret=1,err=183
    23:42:13 712    Loader Device Path(\\?\USB#VID_2207&PID_300A#6&8B0A287&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=3212
    23:42:13 712    INFO:Start to test device
    23:42:13 728    INFO:Start to run
    23:42:13 728    INFO:Test device OK
    23:42:13 728    INFO:Start to download IDB
    23:42:13 744    Flash Chip Information:
    23:42:13 744    NO        SIZE(MB)    Manufacturer
    23:42:13 744    ----------------------------------------------
    23:42:13 744    0        8192MB    MICRON
    23:42:13 744    INFO:BuildFlashStateMap start
    23:42:13 744    INFO: FindAllIDB start
    23:42:14 851    ERROR: FindAllIDB failed
    23:42:14 867    Error:Download IDB failed
    23:42:14 867    INFO:LoaderThread failed
    23:42:14 867    ERROR:Run failed
    23:42:17 784    Info:wait for exiting scan thread start
    23:42:18 034    Info:wait for exiting main thread start
    23:42:18 049    ProcessID:1760,ThreadID:4320,RefCount:0
    Of course, I erased IDB on some attempts... Erasing works in both tools w/o errors. What's strange everything works the same way if I have recovery button pushed on stick connect or didn't push it...
    Pls help me Thanks
    Well, I finally managed to fix this and flash new firmwareWith 6/7 flash chip pins shorted. Not sure why I didn't get success with that before, maybe my tool was not perfect
    The problem was that with or without recovery button pushed stick always started in "loader" USB mode (green box color in Batch Tool). And I already erased flash (this is why I didn't need button to enter recovery mode: nothing could be loaded anyway) and IDB (not sure what IDB exactly is for and where it is located: in regular flash too or separately addressed). Both ROM Flash and Batch Tool seem to unable to flash in "loader" mode w/o IDB found (but erasing functionality works). But if IDB is OK flashing works fine there (pushing recovery button on start loads to this mode exactly). Finally the only solution is to get to "mask ROM" mode (blue box in Batch Tool) by shorting pins.
    Not sure why I get this problem after flashing Finless ROM, remember I pushed "erase" from ROM Flash Tool before flashing Finless, did this kill IDB? And I'm not sure about those "loader" and "mask ROM" USB mode differences... Flashing RK devices is nighmare comparing even with locked loader devices
      I'm glad you got it to work! I think I'm having the same problem as you on my MK802III. Can you please tell me how you managed to get it to work again?
      Thanks in advance!
        If you flash stock, you should try to follow document about "short circuit" method, look for the doc file in zip
          I used the stock 4.2.2 firmware, changed usb port & changed usb cable. I tried once more by shortening the pins. And it worked right away.
          Am now using the 4.2.2 stock firmware and so far it works fine
