Best wireless throughput w/ good WiFi signal?
    Which Android stick has good WiFi signal and fast wireless throughput speed?
    Seems like all these sticks connect at 65Mbps but what's the maximum wireless speed?
    I've tried Minix Neo X7 (RK3188), TimingPower RK3188, Uhost 2 (RK3066) only getting 3-7Mbps over wireless.
    I have to connect USB ethernet to get 20-60Mbps throughput.
    My Mk908ii shows excellent signal strength and 65mbps connection in the wifi settings, but when I take a Internet speedtest I only get between 2-5mbps on my 13mbps Internet connection, I have tried the speedtest with my phone and computer in the same room, then I get full speed.. Don't know if it is something wrong with my mk908ii or if the wifi is that bad on all of them..
    Torbjørn
      Your wireless download speed depends on what you're paying for, combined with the distance and quality of your wireless setup. 3-7 Mbps might be normal if your TV stick is 20 ft. away from your router, & you're paying for 10 Mbps speed. It's poor if the TV stick is 6 ft. from the router and you're paying for 20 Mbps speed.
      Sent from my Nexus 7 using Tapatalk
      MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
        AW: Best wireless throughput w/ good WiFi signal?
        I get full 10mbit on my 10 mbit line, but only when bluetooth is off...
        _________________________
        tapatalked from GalaxyS3
