Just got a new CS968 tv box from dealsprime.When i connected it to the tv using the supplied hdmi cable there was no video signal. I have checked all the hdmi ports with the same cable, then i change the cable to an old one (that works perfectly with other devices) and the problem is still there. No video out. Then i tested the supplied rca cable in order to check if there was a problem with the hdmi port. The result was the same, no video out.
I did all the test using another tv, the same result. No video.
So, i do believe that is a software problem but i am not sure if i am right. Do anyone believe that a image flash will solve the problem?
Any ideas are welcome.
