is there fix for H264/AVC
Originally posted by tashkas View Posti use fineless 2.1 and i cant play 720p bluray avc movie, it stutters. is there any fix?
Also install the neon codec for MXPlayer and enable H/W+ mode.
Make sure you have a strong wifi signal or use ethernet.
If you only play a couple of movies copy them onto a flash drive or external hard drive and play it of there.
If you're looking for an updated libstagefright, you can get it here: http://www.putlocker.com/file/A7C16BC8061CF7A0. I don't know which stick you have, but this only for RK3066 devices. Just download the file, and put it into /system/lib.
Good luck!
There are currently 2665 users online. 0 members and 2665 guests.
