Any way to fix this?
Stop Game Controller From Affecting Launcher, home button action etc?
Strange
Originally posted by relaxxxrrr View PostThis is annoying and screwing up some games. I do not want my 360 controller navigating launcher apps and being as a home button, exiting games and frustrating stuff like that.
I know it sounds weird but if you do not have a wired 360 controller borrow it get the dead trigger game installed and then add the wired 360 gamepad to the tv box or whatever it is your using on android,or if it is wired still do the same regardless as explained thus far,once in game start your game so it's playing then try the controlls,if it fails to work close your game down and unplug the controller while at the desktop screen of the android device (tv box/tablet etc) then try navigating the menu with the gamepad,you should notice it do as it's told and what you tell it to do now,if not unplug it and try it all again a second time.If it is navigating correctly restart a game in dead trigger and test it out,then map controlls to buttons as you want them in game from the games settings menu and play,it should then work as is supposed to,if you don't like the controlls but it plays dead trigger as told via the gamepad then the gamepad and mapping in android is fine,If your using a wireless reciever at this stage you can go to the main screen disconnect the wired 360 controller and add the wireless reciever and should work in dead trigger if not repeat the process multiple times until it does work,but if your trying say 5 times or more times and no luck then i can't assist further sorry.If it's working ingame fine but not as you want for everything else then you will probably need help from a developer or someone experienced enough to modify some configuration file of some description accordingly to do as you want it to in terms of behaviour,that's where my expertise ends in relation to it all lol.Good luck mate.Last edited by PHYSC; 24 March 2014, 01:12.What is the world if you don't explore?
Dead trigger works fine. The problem is some other games don't work so great. They don't seem to block the launcher control. When you plug the 360 controller in, it controls the launcher desktop; the stick selects icons, button Y launches icons, button A goes back... I think something else is the home... When Dead trigger loads it stops the controller from affecting the launcher and there is no problem, A button no longer goes back etc... Some games don't stop this from happening and therefore the controller doesn't function right in the game.
I had this happen with a few games where there's a button conflict and button A or B exits the game back to launcher home. The only one I can think of at the moment is Angry Birds Go, You can steer with the stick but if you hit A or B the android pops back to home screen and not only that the launcher remembers the stick movements in some kind of cache and icon highlights are flying all over the place and launching random apps. If I could turn off the function of the controller navigating the launcher then I don't think this conflict will happen and mess up certain games.Last edited by relaxxxrrr; 30 March 2014, 12:40.
POSS VIRUS?
Originally posted by relaxxxrrr View PostDead trigger works fine. The problem is some other games don't work so great. They don't seem to block the launcher control. When you plug the 360 controller in, it controls the launcher desktop; the stick selects icons, button Y launches icons, button A goes back... I think something else is the home... When Dead trigger loads it stops the controller from affecting the launcher and there is no problem, A button no longer goes back etc... Some games don't stop this from happening and therefore the controller doesn't function right in the game.
Tere seem to be some seriously nasty little apps getting in via auto installs etc,and also redirects are popping up on webpages allowing dodgy apps to self load.Hence i think you should keep that 360 on it as i use it day in day out.It will cleanup from the little desktop circle stating a percentage click it then click the propeller icon to do a quick cleanup of the device.It's rated no.1 from what i find of reviews online on most i read anyway it is high in the lists of best security apps and it's the only one i know that has removed something from a android yet.What is the world if you don't explore?
Originally posted by relaxxxrrr View Postthe rom is pretty new and clean. it found one vulnerability, fake sms or something. it didn't help the game any.
i also tried the "new" launcher, it's just garbage, keeps saying stuff isn't responding..What is the world if you don't explore?
ok
There are currently 3480 users online. 0 members and 3480 guests.
