Pipo m6 Pro doesn't start up!
    Hi, I recently bought a Pipo m6 pro. I was very happy with the tablet.
    But carelessness was fully discharged battery. The problem is that after trying to charge it and plug it will not restart. What can I do? I have tried booting pressing the reset button, but is not responding.
    Thank you very much
    Hi Salmam
    Try to plug in the USB plug an press power, repeat a few times
      Thaks, but this tablet only charges by DC.
      Another solution?
      I tried with this also but doesn't woks:
        Hi salmam,
        I do not mean charging over USB, simply plug and unplug your USB while charging over DC.
        This worked for me on my m8pro
          I think that my M9Pro (4 weeks old) has just gone the same way.
          Won't fire up at all, on or off USB, on or off AC adapter. Tried using the reset button as well.
          LED next to AC socket comes on, that's all.
          What next? Return to vendor?
            The m6 pro doesn't even have led reference...
              If LED come ON, just wait an hour and after this will boot. Press and hold power button for 6-7 seconds.
                Unfortunately I'm now away from home for a couple of weeks (without tablet) so can't check but the LED doesn't always come on, I can't remember what I'd done when I noticed that it was on. Since then, I don't think that I've been able to make it come on at all.
                I also tried connecting it to a PC with the firmware update software running and that didn't find anything either. There's something alive in there since when you plug it in to the PC, there's a few bing bong's from Windows as though the device appears and disappears a couple of times. It doesn't show up in the drive list either.
