I just got myself a new dual band modem (TP-Link W8980) and I have set up both wireless connection inside the Minix Neo X7. I've never used dual band before so can someone advise whether the Minix Neo X7 can receive from both the 2.5GHz frequency & the 5GHz frequency simultaneously?
If so, how can this be done because when i go into settings for WiFi it only seems to allow me to select one or the other.
If it cant be done, is there any way of activating this?
Being a noob they might be silly questions but surely there must be a way to receive on both at the same time which could vastly improve streaming speeds?
The reason for this question is that when i use XBMC, particularly the Irish TV video addons it constantly buffers which is very annoying. On that matter, if i am connected to my 5GHz WiFi is it normal to still get this buffering or do i need to chnage somethig in my settings to improve the WiFi links?
When i do a speed test on my pc it say my ADSL2 speed varies between about 5,000 - 17,000 Mbps, its very inconsistent. I'd like to know if these speeds are acceptable or whether the buffering i am experiencing is normal for these speeds.
Any help would be greatly appreaciated because this is my biggest issue with XBMC and the Minix Neo X7 at the moment.
JW
