things like icefilms, streams, hd full hd, sucks big time..
MK802IV and XBMC awefull!
Hi out there. I know there has been alot of talking about the HW acceleration on the xbmc android. I installed a nightly build, but the quality is still poor. How can it be that xbmc is so poor at playback? and is there really no solution out there?
things like icefilms, streams, hd full hd, sucks big time..Tags: None
Flash your device with this rom http://www.freaktab.com/showthread.p...-1-9a-*UPDATE* . Theres a world of difference from the original FW
If you like the interface of XBMC, try SPMC that comes with that rom. Exactly the same as XBMC but the HW acceleration actually works in SPMC.
( Kunne bare have skrevet på dansk, så lige du var fra danmark)
Originally posted by locolars View PostFlash your device with this rom http://www.freaktab.com/showthread.p...-1-9a-*UPDATE* . Theres a world of difference from the original FW
The rom you are linking to is to an MK809III does that also work on a 802IV ? and can i flash it on a mac or do i need to visit my mom and use her old pc?
There are currently 2271 users online. 1 members and 2270 guests.
