After rooted Next8P12 (NXM805MC) MX Player Brightness control doesn't work
    After rooted Next8P12 (NXM805MC) MX Player, the Brightness control doesn't work.
    When use finger to swipe it up and down vertically on the left hand side.
    How can I solve this problem ?
    Works on mine.
    Mine is the Black Friday 2012 version... is yours newer?
    Are you using the newest version download from the play store?
    Freaktab Rom Developer
      try this if it work and report
      go to settings>player>android 4.0 compatible mode and check
      if not working try this settings>general>reset settings
        What are you talking about ?
        Are you talking about the same settings in this pic ?
ID:	431800Click image for larger version
        I tried clear data , but it doesn't work either.
        That is the only thing I can do in the setting.
        What you mention there is no such menu on Next8P12.
          Not working on mine-
          Manufactured in October 2012 version.
          I using MX PLayer Pro 1.7.20 version
          Originally posted by shaunmt View Post
          Works on mine.
            [ATTACH=CONFIG]4746[/ATTACH][ATTACH=CONFIG]4746[/ATTACH]
            man
            i mean the program setting---mx settings---in mx app settings
              I did the settings>general>reset settings but did not work.
              But I couldn't find- settings>player>android 4.0 compatible mode and check
                what version u got ?
                    download this
                      delete ur app and install it again
                        What is this file for ?
                        Do I need to install this app. together with the MX pro. version that I have ?
                        Would that fix my brightness problem ?
                          it s the same app but from deffrent source
                            So the adjustment for brightness (up and down) on left hand side of screen when using the MX player is working for you with this app after rooting the tablet. ?
                              yeah
                              man i done a lot of things after rooting ...mx player wasent one of the problems
