I do not own an iBall Slide tablet, so this is untested. If you want to try, do so at your own risk and report the results here.
This ROM is:
Full Root with SuperSU
Full debloat
Init.d support added
Busybox commands added
English default with complete Android language support
Working CWM Recovery added (Installed after first boot)
Auto Install added on first boot (see this thread for details of this feature)
Google Play Store fixes added to allow for more compatibility
4gb default user app space with more parameter choices (I'm not sure how much NAND you have, so just make sure your tablet will support 6, 8 or 12gb before you attempt to flash)
Boot animation by Tattman65
Reboot App by Petrus
First Time User's Guide included (read this before you attempt to flash this ROM)
RKBatchTool included as an alternate tool to reboot to flash mode
Rockchip Driver Installer app included in the ROM kit
Download
Enjoy!!!!!
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!! This fund helps me buy new tablets for testing.
