Found a fix for finless 1.7,1.8 and quickshot rom and sixaxis app not working
Originally posted by Crashnet2000 View Post
Originally posted by kennythewise View PostHave you paired your controller with a USB cable and did sixaxis apps gave you the message master address updated if you did it well sixaxis should ask for USB permission. After that you must disconnect the USB cable then you force stop the bluethoot share and it should work. I use quickshot ROM v2 with this fix and it works perfectly. You need to pair the Mac address of your controller only once.
Originally posted by lucaxion View Postman, sorry but i'd tried all of the method but still, no works for me,
my device is neo x7 with quickshot v2 ROM too....
does anyone have other solutions?
You know if you freeze it with titanium, you have have to have the paid version of titanium backup? Maybe try to clear data on the sixaxis app, then uninstall. Then freeze the bluetooth share apk, reboot, check to make sure it's still frozen, then install sixaxis and try that.
Originally posted by Bradleyw801 View PostMaybe you can give some more details about what you have tried? For example, was sixaxis installed before you disabled/and or froze the bluetooth share APK?
1. with bluetooth set to on, i've paired the controller, disconnet it, then i forced stop the bluetooth share, back at sixaxis app, then i start... but not working
2. still with bluetooth set to on, i've paired the controller, disconnet it, press the start, then i forced stop the bluetooth share.... still not working
i'd tried with bluetooth set to off, but i think that'll not work,
coz i think the app need the bluetooth to pair with the controller, aaand the fact, not working that way too.
so it wrote "pair" not "pair controller" i dont know if this kind of different app or not, but on my gal-note it wrote "pair controller" and it work just fine without any other setting needed,
oh yeah one more thing, on my neo x7 after i press the start button on the app, it says :
"attempting connection type 1...
driver starting..." and sometimes
"touch screen device created..."
on my gal-note that works perfectly, it says like this "attempting connection type 2... driver starting... touch emulation (type B) blablabla... succesfully configured bluetooth, listening for contollers...
after i pressed the ps button, it just pair easily...
so what is my problem i have with my x7?
The app can update the mac address in the controller if you have it plugged in via USB and hit pair controller. But, if that's not working, then you should probably use the sixaxis pair utility for windows. Download it here (http://www.dancingpixelstudios.com/s...ller/tool.html)
Once the controller has the same address as your Minix, then make sure bluetoothshare is disabled before you even start the app. The sixaxis app doesn't need the bluetooth share apk at all. If you are rooted, which I assume you are if you are using sixaxis, then it takes control of bluetooth all on it's own, so make sure it's completely off at all times. You never need it on, ever, not even when updating the mac address of the controller.
Let me know if you are still lost.
Originally posted by Bradleyw801 View PostThe pair controller button is just to update your controllers bluetooth address to match that of your device. If you have updated the bluetooth controller to match your Note, then it won't work with Minix unless you change it's internal bluetooth mac address. That button should really say something like update controller address, because it's not really pairing it, it's preparing it to be paired.
so basicly i dont need the bluetooth set to on at all right, and i just updated my internal bluetooth adress for the controller, wow, i've been strugling with something simple man, thx for the advice, that's really helping.
so it works now, for the next i want to pair again, should i do the same thing?
i meant for the pair button? need to do that again? or just make sure to forced stop bluetooth share, and just hit the start button on the app and ps button on the controller?
Originally posted by lucaxion View Postoh my great good lord..!! it works man..!! thank you man,
There is actually a setting on the sixaxis app that let's you "autostart driver". Which means it's always listening for your controller. If the controller mac address is updated to the Minix, then you should be able to just hit the center button on the controller any time you want to pair, and that's all you have to do.
I can pair my controller but or some reason cannot change the ime to sixaxis I am on quickshot v2 rom and an oc'd kernel. Any help is appreciated thx.Last edited by jarheadm249; 04 May 2014, 00:26.
There are currently 2143 users online. 2 members and 2141 guests.
