I have installed Linux on my RK3188 TV Stick.
At some point I needed to unplug the PSU, so I have stopped the system with a "shutdown now" command. It has never wanted to reboot after that.
If I am attaching the device on my WinXP PC USB, I can see the "rockchip" thing appear in the devices manager. Means the driver was correctly installed if I'm not wrong. There is a sall reset button on the side. If I press this button before I plug it in, then the same devices appears in Win XP Device manager. But it is not detected by the RK Flash Tool.
I must say that when I have installed Linux for the first time, this "reset" button was not working as expected either. When pressed, it was rebooting in an unknown mode, but no flash mode (no hdmi output, and not detected as in flash mode). I suspect this button is for "recovery" mode, but I can't prove it
Now, I don't have Android installed and starting anymore, and I am not able to enter flash mode. I have read here and there a few tips about reviving bricked devices by shorting 2 pins on the Nand to enter Mask ROM Mode:
But the CX919 inside doesn't look enough like MK808. Here is a pic of the opened stick:
I have scratched the sticker on the Nand and got this (damn, a permanent marker stain just in the middle):
I got a look into the Micron web site and found some doc about similar chips:
I have tried booting while shorting pins 8-9 then pins 7-8, but without success. When I do so, the Rockchip devices doesn't show up in the WinXP device manager, no "bong", and the flash tool doesn't detect the device. As soon as I "unshort" the pins, then the devices shows up in the device manager, but isn't recognized by the flash tool...
Any suggestions?
Regards
dotvav
