Annoying
Annoying
I Used the Modified Stock recovery 3e to root my next7p12. I'm not sure when this started but about the last 20 times I boot. I get this message display. "Upgrading Android Optimizing apps 1-20". The tablets works fine. Why is it doing that? I have read a few other forums and they said it could happen several times after rooting. I've booted it prob 30 times or more since. It's still doing it.I am the Dude! TheDudeLeeMan! -
Originally posted by thedudeleeman View PostI Used the Modified Stock recovery 3e to root my next7p12. I'm not sure when this started but about the last 20 times I boot. I get this message display. "Upgrading Android Optimizing apps 1-20". The tablets works fine. Why is it doing that? I have read a few other forums and they said it could happen several times after rooting. I've booted it prob 30 times or more since. It's still doing it.
I have not read anything suggesting that it only affects rooted devices.
ShaunMTFreaktab Rom Developer
figured it Out!
It was an app causing the problem. I am pretty sure it was "Android Tuner" that cause the issue. All I did was Run the original "Modified Stock recovery 3e" again and watch closely to the apps I installed. I'm sure that is the one... hope helps out somebody else. Btw thanks for you quick reply.. Any root you'd like me to try on this nextbook amlogic base I'll be happy to try!I am the Dude! TheDudeLeeMan!
I have the same problem too.
After I flashed the smt_gapps-ics-20120429-signed.zip I got that problem.
Did you flash the smt_gapps-ics-20120429-signed.zip ?
I assume "Android Tuner" was inside the file so you unknowingly installed it ?
So can one uninstall Android Tuner ?
If so how can you do it ?
Originally posted by thedudeleeman View PostIt was an app causing the problem. I am pretty sure it was "Android Tuner" that cause the issue. All I did was Run the original "Modified Stock recovery 3e" again and watch closely to the apps I installed. I'm sure that is the one... hope helps out somebody else. Btw thanks for you quick reply.. Any root you'd like me to try on this nextbook amlogic base I'll be happy to try!Last edited by zhongjai; 18 January 2014, 04:57.
There are currently 2345 users online. 0 members and 2345 guests.
