My Tablet is : Pipo Max-M8 Pro
Currently running under : kasty-pipo-m8_pro-422-20131111-rooted4.zip custom Jelly Bean Firmware.
Particulars are :
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.4.3 (GCC) ) #282 SMP PREEMPT Tue Sep 17 14:38:20 CST 2013
Android 4.2.2 JB: rk30sdk-eng 4.2.2 JDQ39 eng.root.20131111.151640 test-keys
ro.rksdk.version=RK30_ANDROID4.2.2-SDK-v1.00.00
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- Certificate Center will ask for product key, which is not needed, just hit later and connect to Internet and it will be activated
- any update received thru OTA may interfere with our custom firmware, we recommend not to apply any OTA update
Custom firmware features:
- root with latest SuperSU version 1.65 (free version)
- removed most Chinese and unnecessary applications
- Google Play Store fixes so more application are visible/compatible
- updated busybox v1.21.0.git (2012-11-29)
- Unix like init.d boot scripts support, more details on init.d scripts here
- changed permissions on external sdcard to allow write access
- increased space for applications (/data partition) to 4 GB
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
- NEW! : optional ClockworkMod (CWM) Recovery easy install package
- all launchers have been kept: stock Android, Kid Launcher and PiPO launcher
1). Unfortunately,Pipo launcher has stopped.
Annoying pop-up now and often.
2). Unable to download any software apps. + tools fom Google Play Store.
The download sems to take indefinitely,but nothing is happenning(NO DOWNLOAD and INSTALLATION),except the horizontal activity bar(line) for downloading the software is moving constantly.
Please Help me out from these 2 particular problems as stated above.
